SIVGA P-II Headphone Planar Magnetic Over-Ear 32Ω 98dB 20Hz-40kHz
After 3 years of research and development, optimizations and innovations, the planar magnetic P-II headphone from Sivga is here. A high performance model, using high quality components and benefiting from an elaborate design, based on the use of a wooden envelope.
By buying this product you get 44 loyalty points
Reference : 15720
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 24-04-2025.
Sivga P-II
Sivga P-II Casque Planar Magnetic Circumaural 32Ω 98dB 20Hz-40kHz
After 3 years of research and development, optimizations and innovations, the planar magnetic P-II headphone from Sivga is here. A high performance model, using high quality components and benefiting from an elaborate design, based on the use of a wooden envelope. The P-II is equipped with planar magnetic drivers with 97 x 67mm composite diaphragms, which have been designed to offer a balanced and natural reproduction, coherent over the whole frequency range, while being able to reveal many details and a large sound stage.
OTV™ Planar diaphragm driver
The planar magnetic drivers are combined here with Sivga's OTC technology. With their ultra-thin composite diaphragms and aluminum-plated circuitry, the P-II's drivers are very thin and light. The dual magnets and 108 perfectly arranged perforations also provide excellent airflow. A design that promotes a beautiful dynamic and rich sound.
A stylish and comfortable headphone
Based on extensive data from big data on the shape of many people's faces and heads, Sivga was able to optimize the P-II's ear cushions with a unique slanted design, allowing for a perfect seal between the headphone and the wearer, but also a perfect fit. The space inside the ear cushions forms an oval, allowing the headphones to surround the ear. Each pad is made of high quality leather and a soft, comfortable velvet-like fabric.
Headband & Rotating Headphones
The P-II's headband is made of stainless steel, while the headphone attachments are made of aluminum. The headband uses a leather cover with a curved and padded design to limit pressure on the head. The headband is also adjustable to fit all body types. Practical, the earphones can swivel on themselves up to 90°.
Wood & Metal
The shell of the headphones combines walnut wood and CNC machined metal parts. This wood was selected for its acoustic properties and its aesthetics. A beautiful perforated grille finishes the P-II, giving it a luxurious design.
High quality cable
The P-II cable, detachable, uses 6N copper conductors, ensuring a perfect transmission of the signal. Its input connector is a 4.4mm jack. A 4.4mm female to 3.5mm male jack adapter is also provided.
Product typeHeadphone
Headphone typeOver ear
Transducer typePlanar magnetic
Dimensions Transducer size97 x 76mm
Frequency response20Hz - 40kHz
Sensitivity98dB ±3dB
Impedance32Ω ±15%
Cable length1.6m ±0.2m
Cable connectorJack 4.4mm
FinishBlack walnut
Weight420g
Package1x Sivga P-II
1x Jack 1.6m cable
1x Jack 4.4mm to Jack 3.5mm cable
1x Carrying case
1x Cable bag
ColorWalnut
Impedance (Ω)32
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
After 3 years of research and development, optimizations and innovations, the planar magnetic P-II headphone from Sivga is here. A high performance...
