SPIRIT TORINO TWIN PULSE Headphone Open Circumaural Jack 2.5mm TRRS 4000mW 64 Ohm 15Hz - 22kHz
The Twin Pulse is the top of the range Spirit headphones in the Torino series. Every detail has been studied to obtain an unequalled tonal balance and speed of response, without forgetting an essential factor: listening pleasure.
By buying this product you get 289 loyalty points
Reference : 14731
2 899,00 €tax incl.
2 415,83 € tax excl.
Spirit Torino Twin Pulse
Spirit Torino Twin Pulse Casque Ouvert Circumaural 4000mW 64 Ohm 15Hz - 22kHz
All the manufacturer's headphones have in common what the brand calls "Spirit Sound", an innate sense of rhythm, determined by an impressive dynamic similar to what can be felt during a live concert.
The Twin Pulse Isobaric System technology, from which the name of the headphone is derived, is the first isobaric solution applied to a headphone. The system consists of two high-performance speakers connected in series and moving synchronously across the entire audio spectrum. This innovative configuration allows the speakers to transmit the aerodynamic flows from the vents faster for impressive dynamics. This design also reduces distortion and dynamic compression, doubles the power handling capacity of the headphones and provides impedance for efficient amplification.
The Grand model features a dense, dynamic and airy sound, making it particularly effective for listening to Rock, Jazz or Classical music.
Spirit Sound: In Pursuit of Perfection
The "Spirit Sound" philosophy of the brand can be defined by the following points:
  • Inertial frame system
  • Efficient current transmission
  • Treatment of resonances
  • Processing of sound reflections within headphone chambers
  • Specially designed Nhoord Audio loudspeakers according to Spirit specifications
  • Patented Twin Pulse® isobaric system
  • Balanced connection with separate masses
  • Digital mapping and compensation
  • Individual fine tuning
Spirit Torino Grand Casque Ouvert Circumaural 2000mW 32 Ohm 97dB 25Hz - 20kHz
Generally speaking, a headphone consists of a chassis, speakers with moving assemblies, ear pads and a headband. The development of the inertial system involves the interaction between the chassis and the mobile unit of the loudspeaker. In practice, each time the mobile unit of the loudspeaker moves in order to create a sound wave, an equal and opposite thrust will be exerted on the chassis which, by moving backwards, will decrease the dynamic impact. Spirit's inertial system provides the necessary mass to minimize this recoil effect and ensure maximum dynamic performance during sound transients.
The brand's approach to current transmission is as radical as it is simple: preserving the energy supplied by the amplifier to the loudspeakers, avoiding dispersion. For this reason, the cabling does not incorporate intermediate connectors but is soldered directly to the speakers, eliminating two solders and a connector contact that could alter the integrity of the electrical signal.
The search for the cabling to be used was also tedious and required years of development work to arrive at a final configuration consisting of a 4-strand anti-inductive braid made of class 5 OFC Copper coaxial cables. This cable was designed by the Italian company Tasker, based on Spirit's specifications.
For connectors, the brand has turned to the Neutrik brand for balanced connections with separate grounding.
Based on the principle that each material has a specific behaviour with regard to resonances, and that the headphone is not a musical instrument but an instrument for the reproduction of recorded music, the "Spirit Sound" philosophy states that any sound colouring induced by chassis resonances and superimposed on the sound of the loudspeakers must be completely eliminated.
To achieve this result, Spirit has based its work on the study of the behaviour of the materials that make up their headphones. A Dural frame with a layer of Dynamat Extreme™ was designed. The latter is in fact a composite material used in particular for car audio applications and providing particularly effective damping. This combination of Dural and Dynamat Extreme allows the damping of the resonance frequencies of aluminium.
Treatment of internal reflections
This very important aspect of obtaining a faithful sound reproduction has also been particularly worked on. All the inner walls of the Spirit headphones are covered with felt to effectively dampen internal reflections. The material used for the ear pads has also been carefully selected, as this can form a second resonance chamber.
The Twin Pulse Isobaric System® technology requires an open structure in order to evacuate sound pressure without affecting the piston movement. The cushions are made of high density ZF foam and have been studied to offer a semi-open cell structure and a shape that guarantees comfort and the correct distance from the point of emission.
Nhoord Audio custom speakers
The integrated loudspeakers have been designed by leading brand Nhoord Audio according to Spirit's specifications to achieve a dynamic and natural sound reproduction.
In the same way as in the development of an engine, the focus was on the exhaust and intake of the air flows generated by the movement of the piston of the mobile unit. Thus, Twin Pulse technology has 4 rear ventilation ports allowing maximum freedom of movement even at low frequencies, for instantaneous impulse response.
The rear structure of the loudspeakers is treated with petals of Dynamat Extreme™ interposed between the vents to make the structure even more inert. The diaphragm is treated by Nhoord Audio with a special gel that optimizes the behavior of the loudspeaker at high frequencies.
Spirit integrates in its headphones the proprietary Twin Pulse Isobaric System® technology, exploiting the isobaric charging concept.
In HiFi, many brands have used this charging system, mainly to improve the efficiency of low frequencies by exploiting the resonance phenomenon of two woofers which, not being charged in the same way, can have frequencies in which their movement is in reverse phase, while for other frequencies the resonance phenomenon will give a peak efficiency. In the Twin Pulse system, two open-air wideband loudspeakers have the same load, allowing synchronous movement of the two moving units across the entire audio spectrum. To ensure perfect synchronicity, the loudspeakers are adjusted with a very low tolerance.
The design advantage of Twin Pulse technology is that the two speakers work together in the exhaust and intake air streams. They will therefore be less affected by the aerodynamic "braking" effect caused by the rear vents and will have a greater ability to stop their movement by countering the hammer effect generated by the air column contained in the chassis chambers.
The Twin Pulse Isobaric System® technology also benefits from the following aspects:
  • Connection of the two loudspeakers in series with a consequent increase in the capacity of the headphone to support the power.
  • Double the load to the amplifier for higher loudspeaker efficiency.
  • Reduction by half of the linear movement of the moving units, which even at high volume will remain in an optimal range of excursion, in which the suspension has a linear elastic behaviour.
  • Increase of the magnetic flux determined by the proximity of the magnets of the two loudspeakers, limiting the efficiency losses of the system.
The separation of the masses enables the true potential of a headphone to be delivered. Typically, in a conventional headphone, the negative pole of the left channel is connected to the negative pole of the right channel, making the two speakers interdependent in their movement. Spirit therefore provides separate masses to maximise the low frequency impulse response.
Generally speaking, our listening is more easily influenced by irregularities in the midrange, frequencies to which the human ear is more sensitive. Spirit has therefore created a mapping of the frequency response of their headphones in order to apply digital correction parameters. These settings allow for a natural reproduction while preserving the original signal, the operation being performed in floating point mode before the digital-to-analog conversion.
Product typeHeadphone
Headphone typeOpen Circumaural
Power handling4000mW
Impedance64Ω
Frequency response15Hz - 22kHz
ConnectorJack 2.5mm TRRS
HeadbandSliding
Leather Covering
EarpadsZF Foam (washable at 30°C)
Weight460g
Impedance (Ω)64
Lowest frequency (Hz)15
Highest frequency (Hz)22000
The Twin Pulse is the top of the range Spirit headphones in the Torino series. Every detail has been studied to obtain an unequalled tonal balance...
