TAGO STUDIO T3-03 Headphones
New
The Tago Studio T3-03 is a closed-back headphone designed for audio professionals. Inspired by the brand's T3-01, it offers the precise, faithful sound reproduction essential for monitoring, while benefiting from a lighter, more portable design, weighing in at just 260g.
By buying this product you get 22 loyalty points
Reference : 20610
229,00 €tax incl.
190,83 € tax excl.
Tago Studio T3-03 Closed-Back Dynamic Headphones 70 Ohm 102dB 20Hz-20kHz
TAGO STUDIO T3-03 : Front view
Tago Studio T3-03: Driver with silk membrane
To deliver the most faithful sound reproduction possible, the T3-03 uses a Ø40mm dynamic driver with a membrane coated in silk protein. This coating, the result of collaborative research with the Gunma textile industry, was made possible by refining and dissolving the prefecture's traditional silk to adapt it to the vibrating membrane. The combination of traditional materials and innovative manufacturing techniques has resulted in a driver with very smooth sound reproduction and a natural timbre.
TAGO STUDIO T3-03 : Driver in the middle of a silk ball
TAGO STUDIO T3-03 : used during a studio recording session
Tago Studio T3-03: A lightweight structure
Although the T3-03 uses the same driver as its predecessor, it makes a number of changes to the structure of the headphones themselves to incorporate feedback from their first model. The T3-03 swaps the wood of its predecessor's rear panel for a thinner, lighter structure, bringing the total weight of the headphones down to 260g. Furthermore, for greater portability, the T3-03 has a foldable structure, greatly reducing the space it takes up in a bag so you can take it anywhere.
Product typeHeadphones
Headphone typeClosed-back
Driver1x Ø40mm dynamic driver
Sensitivity102dB
Impedance70Ω
Headphone connectionJack 3.5mm
Cables length1.2m
3m
Cable terminationJack 3.5mm
Frequency response20Hz-40kHz
Power handling1000 mW
Weight260g
Package1x Tago Studio T3-03
1x 3.5mm jack cable 1.2m
1x 3.5mm jack cable 3m
1x Carrying bag
1x 3.5mm jack to 6.35mm jack adapter
Impedance (Ω)70
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Headphone / Earphone connectorJack 3.5mm
TAGO STUDIO T3-03 Closed-Back Dynamic Headphones 70 Ohm 102dB 20Hz-20kHz
The Tago Studio T3-03 is a closed-back headphone designed for audio professionals. Inspired by the brand's T3-01, it offers the precise,...
