SPÉCIFICATIONS | |
Type de haut parleur | High-power sound pro loudspeakers with light chassis |
Power | RMS : 300 W MAX : 600 W |
Impedance | 8Ω |
Sensibility | 101dB @ 1W/1m |
Frequency response | 36Hz - 300Hz |
Diameter Coil | 63mm |
DC Coil Resistance (Re) | 5.4Ω |
Coil Inductance (Le) | 0.75mH |
Resonance Frequency (Fs) | 36Hz |
Mecanical Q (Qms) | 4.13 |
Elactrical Q (Qes) | 0.48 |
Total Q (Qts) | 0.43 |
Mouvement mass Air (Mms) | 71g |
Compliance (Cms) | 0.28 mm/N |
Emissive surface (SD) | 880cm² |
Force factor (BL) | 13.5Tm |
Volume of air mass equivalent to mobile crew compliance (Vas) | 265L |
Maximum linear excursion (Xmax) | 3.5mm |
Material | Papier cartonné renforcé |
Suspension Material | Petit plis imprégné |
Magnet type | Neodynium |
Total diameter | 315mm |
Total depth | 135mm |
Magnet Diameter | Ø140mm |
Weight | 2.5Kg |
Color | Blue |
Speaker Power (W RMS) | 300.0 |
Speaker Type | Woofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 380.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 101.0 |
Max Linear Excursion (Xmax) (mm) | 3.5 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 4000 |
