By buying this product you get 40 loyalty points
The new Blue Components from IMG Stage Line: subwoofers with a particularly low low frequency for high efficiency, double spider mechanically very stable: professional bass for extreme low pressure Professional Subwoofer, 2000 WMAX, 8 Ω With double centering and settings for powerful bass even in medium cabinetry. Yield above average. The long stroke construction allows a mechanical transposition of extreme power, a subwoofer for truly deep sounds. Suitable for use in professional installations, in disco and on stage. |
![]() | Specifications Speakers | ||
![]() | Impedance (Z) | ![]() | 8 Ω |
![]() | Resonance frequency (fs) | ![]() | 36 Hz |
![]() | Maximum bandwidth | ![]() | f3-1800 Hz |
![]() | Freq. cut. (Fmax). | ![]() | 750 Hz |
![]() | Maximum power | ![]() | 2000 WMAX |
![]() | Nominal power (P) | ![]() | 500 WRMS |
![]() | Pressure sound. (1W / 1m) | ![]() | 98 dB |
![]() | Compliance susp. (Cms) | ![]() | 0.13 mm / N |
![]() | Movable mass (Mms) | ![]() | 141 g |
![]() | Mechanical resistance (Rms) | ![]() | 6.9 kg / s |
![]() | Mechanical overvoltage. (Qms) | ![]() | 4.75 |
![]() | Electrical overvoltage (Qes) | ![]() | 0.54 |
![]() | Fact. total overvoltage (Qts) | ![]() | 0.48 |
![]() | Volume equ. (VAS) | ![]() | 250 l |
![]() | DC resistance. (Re) | ![]() | 6 Ω |
![]() | Inductance coil. (The) | ![]() | 1.65 mH |
![]() | Coil diameter | ![]() | 100 mm |
![]() | Coil support | ![]() | Kapton |
![]() | Height of winding | ![]() | 20 mm |
![]() | Height gap | ![]() | 8 mm |
![]() | Linear Excursion (X MAX) | ![]() | ± 6 mm |
![]() | Transmitting surface (Sd) | ![]() | 1163 cm2 |
![]() | Flight. air displaced (Vd) | ![]() | 698 cm3 |
![]() | Force factor (BxL) | ![]() | 17.49 Tm |
![]() | Ref. (No) | ![]() | 2.25% |
![]() | Magnet diameter | ![]() | 238 mm |
![]() | Magnet weight | ![]() | 93.4 oz. |
![]() | cutting | ![]() | Ø 420 mm |
![]() | Mounting depth | ![]() | 205 mm |
![]() | dimensions | ![]() | Ø 470mm |
![]() | Weight | ![]() | 11.1kg |
![]() | Recommended Min Volume | ![]() | |
![]() | closed | ![]() | 120 l |
![]() | bass reflex | ![]() | > 150 l |
Speaker Power (W RMS) | 500.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 460.0 |
Diaphragm type | Paper |
Efficiency / Sensitivity (dB) | 97.0 |
Max Linear Excursion (Xmax) (mm) | 6.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 3500 |
