Monacor SPA-110PA
Professional loudspeaker series with cast aluminum bowl. Professional Bass Loudspeaker, 300 WMAX, 150 WRMS, 8 Ω
They equip the PAB-110MK2, PAB-112MK2 and PAB-115MK2 speakers and are characterized by Thiele and Small balanced parameters and high efficiency.
Features:
Impedance (Z) | 8 Ω |
Resonance frequency (fs) | 61 Hz |
Maximum bandwidth | f3-5000 Hz |
Maximum power | 300 WMAX |
Rated power (P) | 150 WRMS |
Average sound pressure. (1 W / m) | 97 dB |
Compliance susp. (Cms) | 0.23 mm / N |
Moving mass (Mms) | 29 g |
Coil diameter | 50 mm |
Coil holder | Kapton |
Linear Excitation (XMAX) | ± 4 mm |
Transmitting surface (Sd) | 364 cm2 |
Magnet Weight | 1.2 kg |
Weight | 3.2 kg |
Mechanical overvoltage. (Qms) | 10.68 |
Electrical overvoltage (Qes) | 0.49 |
Fact. total surge (Qts) | 0.47 |
Volume equ. (VAS) | 38 l |
DC resistance. (Re) | 5.2 Ω |
Force factor (BxL) | 10.4 Tm |
Inductance coil (The) | 0.68 mH |
Speaker Power (W RMS) | 150.0 |
Speaker Type | Midbass |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | N/A |
Efficiency / Sensitivity (dB) | 97.0 |
Max Linear Excursion (Xmax) (mm) | 4.0 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 5000 |
