CELESTION CDX1-1430 Horn Speaker Driver High Range 50W 8 Ohm 2000Hz - 20kHz Ø2.5cm
Reference : 1283
136,34 €tax incl.
113,62 € tax excl.
Even in the field of horn speaker systems, the CELESTION range offers interesting alternatives with excellent technical properties.
Horn motor, 100 W MAX , 8 Ω
1 "horn motor with standard mounting 2 or 3 screws, neodymium motor system in new design, cooling, low weight, compact dimensions Very linear frequency response, very high efficiency for very low distortion: the acoustic values indicated result from the combination with the MRH-200 horn. From 3000 Hz approximately, applications in 2-way systems or even with low 15 "are possible with this engine.
Impedance (Z)8 Ω
Resonance frequency (fs)1750 Hz
Maximum bandwidthfx-19000 Hz
Crowds. cutoff (fmax.) (12dB / oct.) 3000 Hz
Maximum power100 W MAX
Rated power (P)50 W RMS
Pressure sound. (1W / 1m)110 dB
Angle dispersion (green / hor)according to flag
Coil diameter34.4 mm
Magnet diameter75 mm
cuttingaccording to flag
Mounting depthaccording to flag
DimensionsØ 75 mm x 75 mm
Weight450 g
Speaker Power (W RMS)50.0
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
