DAYTON AUDIO H07E Elliptical Waveguide High Frequencies Ø15.2cm
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures accurate reproduction and an open sound stage, allowing you to reveal the full potential of your tweeters.
Reference : 14357
11,90 €tax incl.
9,92 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
Dayton Audio H07E
Dayton Audio H07E Pavillon Wave Guide Hautes Fréquences Ø15.2cm
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and low expansion rate. It ensures accurate reproduction and an open sound stage, allowing you to reveal the full potential of your tweeters. The H07E is molded from high quality plastic and its screw thread is the industry standard 1-3/8" x 18 TPI. Its elliptical shape provides 80° horizontal and 50° vertical coverage and offers an acoustic load up to 2200Hz.
Thread not compatible 1 3/8" 18 UNEF.
Product typeWaveguide for high frequencies driver
Output diameterØ15.2cm
Screw thread format1-3/8" x 18 TPI
Acoustical loadDown to 2200Hz
Coverage patternHorizontal : 80°
Vertical : 50°
MaterialABS
Total dimensions (W x H x D)14.9 x 14.9 x 9.5cm
Speaker Power (W RMS)NC
Speaker TypeN/A
Impedance (Ω)NC
Loudspeaker diameter (mm)152.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
This horn allows you to tune a high-frequency driver to your listening space without distortion thanks to its unconventional geometric shape and...
