Audio Isolation Transformer Ground Loop RCA
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion.
4.5 / 5
Reference : 13755
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 15-09-2026.
Transformateur Audio d'Isolation Boucle de Masse RCA
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion. To do this, the circuit integrates a unique impedance conversion and spectrum isolation system with anti-EMI capabilities. In short, this product solves the problems of distortion and noise that can be caused by a long connection or a difference in electrical potential. A 4KV protection system (ESD) is also integrated, allowing to protect the devices connected to the insulator.
SpEcifications
Product typeIsolation audio transformer
Input / output impedance600Ω
Insulation voltage800V
Insulation resistante100MΩ
THD< 0.5% (30Hz - 20kHz), 0.05% @ 1kHz
Crosstalk< 60dB (20Hz - 20kHz), < 70dB @ 1kHz
SNR> 95dB
Protections4KV (ESD)
Housing materialBrushed Aluminium
Dimensions145 x 110 x 60mm
Weight114g
ColorChampagne
2 reviews
Excelent
Solves ground loops without the compromise of sound quality
This review has been posted for Audio Isolation Transformer Ground Loop RCA
son plus propre avéré
Testé sur 7métres , 2 métres en amont et 5 en aval du transformateur . Comparé par rapport à des connecteurs or rca classiques , le son est net et comme nettoyé (audible sans effort) . Au détriment peur être d'une légére retenue non génante ( rodage ?) . A conseiller.
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a...
