Audio Isolation Transformer Ground Loop XLR
This stereo XLR isolation transformer isolates the audio input/output from the ground in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion.
Reference : 13756
99,00 €tax incl.
82,50 € tax excl.
Transformateur Audio d'Isolation Boucle de Masse RCA
This stereo XLR isolation transformer isolates the audio signal (input/output from the ground) in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion. To do this, the circuit integrates a unique impedance conversion and spectrum isolation system with anti-EMI capabilities. In short, this product solves the problems of distortion and noise that can be caused by a long connection or a difference in electrical potential. A 4KV protection system (ESD) is also integrated, allowing to protect the devices connected to the insulator.
SpEcifications
Product typeIsolation audio transformer
Input / output impedance600Ω
Insulation voltage800V
Insulation resistante100MΩ
THD< 0.15% (30Hz - 20kHz), 0.05% @ 1kHz
Crosstalk< 60dB (20Hz - 20kHz), < 70dB @ 1kHz
SNR> 95dB
Protections4KV (ESD)
Housing materialBrushed Aluminium
Dimensions82 x 63 x 39mm
Weight82g
ColorChampagne
Input
  • XLR
Output
  • XLR
Color
  • Champagne
  • Other
This stereo XLR isolation transformer isolates the audio input/output from the ground in order to considerably reduce...
