Audio Transformer E-9818 600:600
This E-9818 600:600 transformer can be used for a variety of tasks. For example, you can use it to convert a balanced signal into a Single-ended signal and vice versa, or to isolate an audio signal from the rest of the circuit and thus avoid the parasitic noise generated by the latter. With its near-perfect decibel variation of just +/-0.18dB over a frequency range of 20Hz to 20kHz, you can rely on this transformer to deliver Hi-Fi quality. Furthermore, the E-9818 600:600 transformer comes complete with PCB, so compatibility with the system in which it will be installed is assured.
Reference : 19646
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 24-04-2025.
Audio Transformer E-9818 600:600 (Unité)
E-9818 audio transformer
Audio E-9818 transformer dimensions
Wiring diagram
Product typeAudio transformer
Transformation ratio1:1
Spacing betwen pins5mm
Spacing between rows of pins12.5mm
Loss across transformer±0.18 dB
Dimensions22 x 22 x 18mm
Weight30g
Package1x Audio Transformer E-9818 600:600
1x Compatible PCB
This E-9818 600:600  transformer  can be used for a variety of tasks. For example, you can use it to convert a balanced signal...
