CANARE L-2B2AT Balanced Interconnect Cable Ø3.2mm
Reference : 14662
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 23-04-2025.
Câble vendu au mètre
Canare L-2B2AT
Cable sold by the meter L-2B2AT
Here is a custom-length modulation cable made by Canare. It is the thinnest model offered by the manufacturer. It stands out for its excellent flexibility, its 100% aluminum shielding, its drainage wire and its PVC sheath, easy to handle for easy and comfortable assembly.
This model of modulation cable is particularly useful for blocks of devices requiring significant wiring as well as to interface mixers or to carry out the internal wiring of your DIY devices / your racks for a clean and lasting result.
Use example
This cable is particularly suitable for connecting ambitious audio circuits. Many audiophonics products use it as an interconnection between several modules or separate circuits with printed circuit type connectors (XH: 2.54 mm).
Please note, this photo is an illustration of a possible use case. The cable is delivered without connector and it will be necessary to install it yourself.
LengthSold by the meter
General diameter3.2mm
Sheath thickness0.3mm
InsulationIPE
Cond-AWG (Qty./mil)AC - # 25
Cross Sec(16 / 4.73)
Shielding100% aluminum tape
Cond.
D.C.R.
(Ohm / 100m)
≤10.5
CapacitanceConductor - conductor: 73 pF / m
Conductors - shield: 120 pF / m
SheathDupont® Kevlar 29
Diameter (mm)3.2
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
