ELECAUDIO SC-221SPOFC Symmetrical modulation cable SPOFC PTFE Ø8.9mm
4.3 / 5
Reference : 6407
5,90 €tax incl.
4,92 € tax excl.
Fort of its expertise and experience in audio / video cables, ELECAUDIO has designed the SC-221SPOFC high quality, using the best materials available to meet your expectations and needs.
The PC-OFC copper conductors of a large section of 1.25mm² and the Teflon insulation, which ensures high mechanical strength, are a guarantee of a pure and detailed reproduction for your HiFi material.
Double shielding with 100% overlap ensures protection against interference frequencies: A first shield made from copper finely woven, then a second made of aluminum strip.
The whole surrounded by a thick sheath green PVC shining protecting the whole.
The construction with cotton filling and paper sheet in order to hold the 2 conductors, allow to obtain a good general flexibility of the cable.
ELECAUDIO SC-221SPOFC Câble de modulation symétrique SPOFC PTFE Ø 8.9mm
Features:
  • 2 OFC Copper Conductors of section 1.25mm² each, composed of 77 strands of 0.12mm diameter PC-OFC
  • Insulation of drivers in PTFE: high mechanical strength ensures perfect maintenance of tight strands between them
  • Conductor diameter with insulating sheath: 2.50mm
  • Double shielding: Aluminum foil / Braided copper sheath
  • Padding cotton + paper: ensures a good flexibility of the cable while maintaining perfectly the 2 conductors
  • Outer Sheath PVC of Strong Thickness: Resistant to Shocks and Wear
Specifications:
  • Total cable diameter : 8.90mm
  • High end finish
  • Color: Green Scintillant
https://www.audiophonics.fr/images2/6407/6407_ELECAUDIOSC221SPOFC.jpg
Connectors ELECAUDIO RC90-OFC(not supplied)
Diameter (mm)8.9
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingYes
Section (mm²)1.25
Ground / ShieldingYes
4 reviews
Disapointing sound
Not worth the Money ,just a bad cable ,the sound was disapointing compared to the standard ptfe cable i have bought earlier from audiophonics
This review has been posted for ELECAUDIO SC-221SPOFC Symmetrical modulation cable SPOFC PTFE Ø8.9mm
Super bon cable
Très bonne qualité de fabrication , bon produit
Livré rapidement, bravo à l'équipe Audiophonics
tres bien!
au dénudage le soin apporté a la fabrication est évidente. utilisé pour une connectique xlr dans mon cas de figure, l'écoute est littéralement éblouissante et fait mieux qu'un câble xindak (AC-01, qualité du conducteur moindre et connectique en rca, il est vrai), marque pourtant réputé pour la qualité de ses câbles.
si vous voulez utiliser les fiches xlr de la même marque il faudra passer par la case "usinage", le câble étant légèrement trop gros (8.9mm) pour la fiche (8.5mm max)...
incompréhensible pour des produits d'un même fabricant,
d'autant plus dommage que la qualité de l'ensemble est vraiment au rendez-vous.
pour conclure je dirais que ce câble satisfera un grand nombre d'audiophile, même parmi les plus exigeants.
Cable de modulation remarquable, l'association Ag et Cuivre ofc fait miracle dans les aigus et les méduims en aérant la scène et en lui donnant plus de détails. L'ensemble n'est pas sec mais a du corps et de la finesse. Belle réussite.
Dans les basses il y a une bonne précision mais de la discrétion, ce n'est pas un câble pour subwoofer...
L'ensemble est cohérent et fin, voir aérien. Ce câble a une vrai personnalité mais il privilégie la transparence et la fidélité à la musique.
Je le trouve plus qualitatif qu'un Galiléo sur une install de bon niveau.
 (6)
