FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm
This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two conductors made of three layers braided in opposite directions. The inner layer is made of α-OCC copper and the other two are made of α-DUCC copper, materials that ensure perfect electrical conductivity.
By buying this product you get 105 loyalty points
Reference : 16879
350,00 €tax incl.
291,67 € tax excl.
Shipping date: 16-04-2025.
Câble vendu au mètre
Furutech DAS-4.1
This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end audio cables. It features two conductors made of three layers braided in opposite directions. The inner layer is made of α-OCC copper and the other two are made of α-DUCC copper, materials that ensure perfect electrical conductivity. The Alpha (α) cryogenic treatment of the conductors allows the material to be optimized to increase its performance.
Each conductor is insulated with a polypropylene (PP) sheath and held in place by a polyester filling. A triple shielding is then used to repel interference that could alter the integrity of the signal. The whole thing is protected by a double PVC sheath, one of which is NCF, and dressed in a beautiful blue and black braided polypropylene sheath.
Furutech DAS-4.1 Câble de modulation Cuivre OCC DUCC Symétrique Ø10mm
1Braide polypropylene (PP) covering sleeve
2PVC external sheath
3PVC and NCF internal sheath
4Papre foil shielding
5Braided α-OCC copper shielding
6Copper foil shielding
7Non-woven fabric wrap
8Polyester filling
9Polypropylene insulation sheaths
10α-DUCC copper outer conductor (right rotate)
11α-DUCC copper middle conductor (left rotate)
12α-OCC copper inner conductor (right rotation)
Product typeInterconnect cable
Conductorsα-OCC copper
α-DUCC copper
Conductors section1.65mm² (15AWG)
InsulationPolypropylene
Internal sheathPVC + NCF
External sheathPVC
Covering sleeveBraided polypropylene
External diameterØ10mm
ColorBlue and black
QuantitySold by the meter
Diameter (mm)10.0
Number of conductors2
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)1.65
Ground / ShieldingYes
3 reviews
L'aboutissement
Déjà détenteur des DPS et dss j'avais hâte de remplacer mon fa.as 22 par le das . Mon câble est monté entre un master 10 et un he7 connection acss que j'ai modifié de Mini xlr passé en xlr ,Monté avec des cf 601 et 602 . Le résultat est génial mon système était déjà très silencieux mais la je trouve que la restitution à changer on veut toujours plus de détails mais la j'ai trouvé de la chaleur une âme pour faire simple j'ai gagné partout mais ce qui ressort c'est l'intention des chanteurs et des instruments il y a plus d'émotions. Pas facile à expliquer. C'est toujours trop cher mais c'est mon plaisir.
This review has been posted for FURUTECH DAS-4.1 Balanced Interconnect Cable OCC DUCC Copper Ø10mm
Magnifique de vérité et qualité dans les timbres: super produit
Attention Ovni i!!!
Ce câble, est venu en remplacement, du Furutech FA-aS22, chez moi il s'agit d'un câble Hybride RCA FURUTECH CF-102 NCF, et OYAIDE FOCUS 1 Connecteurs XLR Mâle. Ce câble, est a l'image de cette game HDG FURUTECH, au bout d'une semaine : beaucoup de transparence, de véracité des timbres, de finesse, de profondeur, de maitrise, est de lisibilité, d'une définition très poussée ,mais naturelle. Le seul bémol, est qu'il va être très long à roder (le câble secteur FURUTECH DPS 4.1 avait mis environ 500 Heures, pour arriver à Maturité) et son prix relativement élevé, mais je pense que cela en vaut la peine.( Il ya de très bonnes vidéos en ligne, pour le montage des câbles FURUTECH DPS 4.1, sous toutes leurs formes, faites par Furutech).
This Furutech DAS-4.1 balanced interconnect cable offers an absolutely outstanding design quality that will allow you to design your own high-end...
