FURUTECH FA-αS21 Interconnect Cable PC-OCC Ø8mm
Reference : 11382
62,90 €tax incl.
52,42 € tax excl.
Shipping date: 15-04-2025.
Furutech Fa a s21
The treatment of α Alpha copper from Furutech OCC drivers is favored by Furutech engineers to excel in sound reproduction.
The α (Alpha) OCC treatment is done with high purity oxygen-free copper using a particular technological cooling process at very low temperature.
Unlike OFC cables, virtually all impurities are removed at the micron using a special Furutech single casting process.
Electrical characteristics:
  • Maximum conductor resistance: Ω / km 24 (JISC3005 6 20 ℃)
  • Minimum insulation resistance: MΩ‧m> 100 At 1000V 20 ℃
  • Capacitance: MF / M 57.4 at 1KHz
  • Impedance: Ω 53.22 to 10 MHz
  • Inductance: uH / M 2.0 at 1KHz
  • Dielectric strength: V / 1 min. AC 1000 (JISC3005 8)
Mechanical characteristics:
  • Conductor Type: Copper α (Alpha) OCC
  • Internal construction 30 strands of 0.18mm each
  • Insulation Type: Audio Type Resin (Red and White)
  • Diameter: 2.46mm
  • Internal structure: 2 twisted strands together
  • Mechanical damping: Quality cotton Audio and wrapped paper
  • Shielding: (Alpha) Braided conductor
  • Jacket Material: Flexible PVC soft PVC (dark green)
  • Sheath Thickness: 1.0mm
  • External Diameter: 8mm
Diameter (mm)8.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
3 reviews
stunning !!
it's a wonderful cable .. neutral.. rich.. armonic sound without harsness .. i made one rca and another xlr version and both are simply wonderdul.. i use the xlr version between pass xp12 and x350.8 and the rca version between a msb analog dac and vitus ri101 integrated amp...
This review has been posted for FURUTECH FA-αS21 Interconnect Cable PC-OCC Ø8mm
wonderful cable
i have bought this cable.. and made one rca and another one xlr.. in both cases i think the result it's stunning... neutral, rich, armonich without harsness ..
cable modulation symétrique
produit de très bonne qualité, déjà visuellement.
A l'écoute, le résultat est excellent.
 (3)
