MOGAMI 2791 Interconnect Cable Symétrical 0.20mm² Ø5.5mm
4.0 / 5
Reference : 4430
4,00 €tax incl.
3,33 € tax excl.
Shipping date: 22-04-2025.
MOGAMI 2791 - 105 Strand Broadcast Mic. Cable
Câble de modulation symétrique Mogami 2791, comprenant 2 conducteurs composés de 105 fils de 0.002mm² chacun.
Excellent for rugged remote and on stage use in Sound Reinforcement, TV, Radio broadcasting etc. Its compact size together with a heavy duty binder and filler system and a braided shield make it ideal for all continuous handling applications. Exhibits very low microphonic pick - up and can operate at very cold temperatures down to -20°C (-4°F) without losing its flexibility. 105 strands of 44AWG annealed bare copper features ultra flexibility with extraordinary flex life, while maintaining excellent strength characteristics.
Part No. W2791
https://www.audiophonics.fr/images2/4430/w2791.jpg
Part No.W2791
Conductor Size (mm²)0.206mm² (#24AWG)
O.D. (mm)5.5ø (0.217")
Flex Life164,000 cycles
Tensile Strength578 N
ColorsBlack / Red / Yellow / Green / Blue
Braided ShieldCoverage: over 95%
SPECIFICATIONS
Configuration
Part No.W2791
No. of Conductor2
ConductorDetails105/0.05 A
Size(mm²)0.206mm² (#24 AWG)
InsulationOv. Dia.(mm)1.5Ø (0.059")
MaterialXLPE (Cross-Linked Polyethylene)
ColorsRed / Clear
ShieldBraid 0.10A/9/16
JacketOv. Dia.(mm)5.5Ø (0.217")
MaterialFlexible PVC
Roll Sizes50m (164 Ft)
100m (328Ft)
200m (656Ft)
Weight per 200m Roll9kg
ELECTRICAL & MECHANICAL CHARACTERISTICS
Part No.W2791
DC Resistance at 20°CInner Cond.0.09W/m(0.027W/Ft)
Shield0.002W/m(0.006W/Ft)
Capacitance at 1kHz, 20°C
(Partial C. Value)
See below figure*
K086pF/m(26pF/Ft)
K110pF/m(3.1pF/Ft)
Inductance between conductors at 1kHz. 20°C0.8µH/m(0.24µH/Ft)
Electrostatic Noise**250mV Max.
Electromagnetic Noise**0.15mV Max.
Microphonics at 50KW Load**30m V Max.
Voltage BreakdownMust withstand at DC 125V/15sec.
Insulation Resistance100000 M W × m Min. at DC 125V, 20°C
Flex Life**164,000 cycles
Tensile Strength578N
EmigrationNon-emigrant to ABS
Applicable Temperature-20°C~ +70°C(-4°F~ +158°F)
** Using standard testing methods of Mogami Wire & Cable Corp.* Patial Capacitance
Diameter (mm)5.5
Length (m)Sold by length
Number of conductors2
Insulation materialOther
ShieldingYes
Section (mm²)0.2
Ground / ShieldingYes
5 reviews
mogami 2791
Câble avec un bon équilibre. Pas d’aigus brillants ou de basses gonflées.
Parfait pour les systèmes ayant besoin d’apaisement.Les médiums sont définis et l'énergie passe sans souci.
This review has been posted for MOGAMI 2791 Interconnect Cable Symétrical 0.20mm² Ø5.5mm
Bon câble
Bon câble facile d'utilisation
bon cable
bon cable rapidité d'audiophonics je recommande site sérieux
Un top mais...
Ce câble est certes subjectivement droit et restitue les timbres avec justesse, mais avec une tendance à la matité qui fait qu'on ressent un manque de chatoiement des timbres dans le haut du spectre, avec une extension limitée au niveau des harmoniques supérieures qui sont partiellement gommées, ça manque un peu de fluidité.
Un soupçon d'ouverture aurait été la bienvenue, le bas medium souffrant un peu de ce caractère mat;
Le basses sont bien tendues et contrôlées, mais pas abyssales.
Un top de mogami
Un câble neutre sans être plat , l'un des meilleurs MOGAMI que j'ai testé. Excellent rapport qualité prix.
