MOGAMI 2944 Modulation cable OFC Copper 2x0.15mm² Ø2.5mm
4.5 / 5
Reference : 14156
1,30 €tax incl.
1,08 € tax excl.
MOGAMI 2944
wiring cable Instrument
This Mogami wiring cable has two conductors, a ground and a drain. It was first developed for the internal wiring of electric guitars before seeing its popularity extended to all kinds of audio applications. This is the ideal cable to improve / repair the connection between your main circuit and deported some components (potentiometers, VU meters, etc ...)
The conductors of Mogami 2944 are made of copper (OFC NEGLEX) with a section of 0.15 mm². They have a XLPE insulation (cross linked polyethylene) to ensure excellent electrical properties while avoiding narrowing during welding. It also gives a very flexible cable ideal for very limited spaces.
Cable cross-sectional view
Capacitance between conductors
Capacitance at 1 kHz, 20 ° C:
K0: 130pF / m
K1: 12pF / m
TypeCable by the meter
Conductors2x 0.15mm²
conductive materialsOFC
section drivers0.15 mm²
Drain wiref
InsulatingXLPE
External diameter of the cable2.5mm
SheathPVC
DC resistance at 20 ° CConductor: 0.13Ω / m
Shielding: 0.029Ω / m
Capacitance at 1 kHz, 20 ° CK0: 130pF / m
K1: 12pF / m
Inductance between conductors0.6 uH / m
electrostatic noise (test method Mogami Wires & Cable Corp.)20 mV max
electromagnetic noise (test method Mogami Wires & Cable Corp.)0.1 mV
max voltageDC 500V / 15s
insulation resistance10 ^ 5MΩ · m @ Minimum DC 125 V, 20 ℃
Diameter (mm)2.5
Length (m)Sold by length
Number of conductors2
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.15
Ground / ShieldingYes
2 reviews
Bon cable à petit prix
Utilisé pour du câblage interne, le cuivre et le blindage sont de bonne qualité. Il se dénude bien. Parfait pour des petites longueurs.
This review has been posted for MOGAMI 2944 Modulation cable OFC Copper 2x0.15mm² Ø2.5mm
Produit sérieux
Conforme à l'image de la marque.
