MOGAMI W2932 Micro Cable 8 Aanalog Channels Ø11.5mm
The Mogami W2932 is an 8-channel multicore microphone cable, perfectly suited for studios and professional applications that require very good transmission and high-level audio performance.
Reference : 11402
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 22-01-2025.
Câble vendu au mètre
Mogami W2932
Mogami W2932 Câble Micro 8 Canaux Analogiques Ø11.5mm
The insulation of the conductors is made of XLPE (Cross-linked Polyethylene) with excellent electrical characteristics and resistant to welding. Its construction is robust and flexible, allowing easy handling of the cable even at temperatures down to -20°C. The shield made of coiled bare Copper wire allows a superior transmission quality to the braided straps or sheaths while facilitating the assembly.
Product typeMicro cable
Number of channels8
Conductor section0.15mm² (26AWG)
External diameterØ11.5mm
Conductors insulationXLE (Cross-linked polyethylene) Ø1mm
SheathPVC Ø2.8mm
Temperature range-20°C / +70°C
Capacitance (@1kHz, 20°C)K0 130pF/m
K1 12pF/m
Inductance0.6µH/m
Electrostatic noise2.5mV max.
Electromagnetic noise(@ 10kHz)0.1mV max.
Microphonics50mV max. @ 50kΩ/charge
Voltage breakdownMust withstand 500V DC/15sec
Insulation resistance (@ 125VDC, 20°C)100000MΩ/*m min.
Tensile strength of one pair (26°C, 65% RH)274N
QuantitySold by the meter
Diameter (mm)11.5
Length (m)Sold by length
Number of conductors8
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.15
Ground / ShieldingYes
Le classique !
A mon avis, le meilleur 8 paires haute qualité du marché !
This review has been posted for MOGAMI W2932 Micro Cable 8 Aanalog Channels Ø11.5mm
The Mogami W2932 is an 8-channel multicore microphone cable, perfectly suited for studios and professional applications that require very good...
