NEOTECH NECE-1001 Cable for Headphone
New
The Neotech NECE-1001 is an IEM cable featuring 4 silver UP-OCC conductors with Litz multi-strand design. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating.
By buying this product you get 22 loyalty points
Reference : 20545
224,00 €tax incl.
186,67 € tax excl.
Câble vendu au mètre
Neotech NECE-1001Cable for Headphone Litz Silver UP-OCC Ø3mm
NEOTECH NECE-1001 picture
The Neotech NECE-1001 is an IEM cable featuring 4 silver UP-OCC conductors with Litz multi-strand design. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating. This reduces the impact of the skin effect, i.e. a current that flows only on the surface of the conductor at high frequencies, as well as the proximity effect, which increases resistivity. The braids help reduce EMI/RFI interference for a wide soundstage and spatial rendering.
To achieve a good solder joint on this type of cable, it's best to remove the coating on the solder zone, using a soldering flux.
Product typeHeadphones / IEM cable
StructureLitz wire
Conductors4
Conductors materialSilver UP-OCC
InsulationPVC
Section26AWG (0.129mm²)
ColorBlue
PackageSold by meter
Diameter (mm)3.0
Number of conductors4
Insulation materialPVC
ShieldingNo
Section (mm²)0.129
Conductors material (Cable)Silver
Ground / ShieldingNo
NEOTECH NECE-1001 Cable for Headphone Litz Silver UP-OCC Ø3mm
The Neotech NECE-1001 is an IEM cable featuring 4 silver UP-OCC conductors with Litz multi-strand design. This design greatly optimizes signal...
