The Neotech NECE-3200 III is an IEM cable featuring a 4-conductor Litz multi-strand design in silver-plated UP-OCC copper. This design greatly optimizes signal transmission, while the Litz wire structure insulates each strand with a polyvinyl chloride coating. This reduces the impact of the skin effect, i.e. a current that flows only on the surface of the conductor at high frequencies, as well as the proximity effect, which increases resistivity. The braids help reduce EMI/RFI interference for a wide soundstage and spatial rendering.
To achieve a good solder joint on this type of cable, it's best to remove the coating on the soldering zone using a soldering flux.
Product type | Headphones / IEM cable |
Structure | Litz wire |
Conductors | 4 |
Conductors material | UP-OCC silver-plated copper |
Insulation | PVC |
Section | 25AWG (0.162mm²) |
Color | White |
Package | Sold by meter |
Diameter (mm) | 3.0 |
Number of conductors | 4 |
Insulation material | PVC |
Shielding | No |
Section (mm²) | 0.16 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Ground / Shielding | No |
