This product has been replaced by the new version, the NEOTECH NECE-3001 MKII OCC Copper Cable.
Câble IEM Cuivre UP-OCC Litz Ø 3mm
Neotech NECE-3001 is an IEM cable with 4 Litz UP-OCC copper conductors, PVC insulation and black Nylon sheath.
Litz wire is a conductor in which each strand is electrically insulated by a polyurethane coating. This reduces the impact of the skin effect, i. e. a current that only flows on the surface of the high-frequency conductor, as well as the proximity effect that increases resistivity. Such a design is particularly suitable for audio use as it improves conductivity and limits cable resistivity, resulting in excellent audio reproduction.
Note: To achieve a good weld on this type of cable it is preferable to remove the coating with a welding flux.
Product type | IEM Cable |
Conductors number | 4 |
Conductors material | UP-OCC Copper, Litz wire |
External diameter | 3mm |
Conductors diameter with insulation | 0.9mm |
Copper conductor diameter | 0.6mm |
Insulation material | PVC |
External sheath | Braided Nylon |
Color | Black |
Quantity | Sold per meter |
Length (m) | Sold by length |
Number of conductors | 4 |
Shielding | No |
Section (mm²) | N/A |
Conductors material (Cable) | Copper |
