NEOTECH NECH-3001 Litz UP-OCC Copper Cable for Headphone Ø3mm Brown
4.0 / 5
Reference : 12154
23,90 €tax incl.
19,92 € tax excl.
This product has been replaced by the new version, the headphone cable NEOTECH NECE-3001 MKII Cuivre UP-OCC Litz.
Câble Neotech NECH-3001 au mètre
Neotech Cable NECH-3001
The Neotech NECH-3001 cable is a headphone cable with 4 copper conductors Litz UP-OCC, with PVC insulation and a nylon braided sleeve.
The Litz cable means that each strand of copper is electrically insulated with a polyurethane coating. This reduces the impact of the skin effect (current that circulates only on the surface of the high-frequency conductor) and the proximity effect (increased resistivity). This process is ideal for audio since it improves conductivity and limits the resistivity of the cable, to ensure excellent sound reproduction.
ize: 16px; line-height: 1.5em; text-align: center; margin-left: auto; margin-right: auto; width: 80% ">It should be noted that, in order to achieve a good weld, the coating must be removed by means of a flux for welding.
TECHNICAL CHARACTERISTICS
  • Total diameter: 3mm
  • Conductor diameter with insulation: 0.9mm
  • Copper conductor: 0.6mm
  • Insulation material: PVC
  • Conception Litz
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
Section (mm²)0.50
Bon produit
Produit impeccable qui m'a permis de recabler un Sennheiser HD800 et un Heddphone. Assez fin et souple, il peut même être doublé sans problème, ce qui est plus pratique au final. Seul petit bémol, pas facile d'étamer le fil de Litz (avec les moyens du bord) sans que l'isolant en PVC ne prenne un coup de chaud.
This review has been posted for NEOTECH NECH-3001 Litz UP-OCC Copper Cable for Headphone Ø3mm Brown
