NEOTECH NEI-2001 Interconnect Cable Pure Silver Shielded PTFE Ø11mm
The Neotech NEI-2001 cable consists of 3 pure silver conductors with shielding. It is perfectly suited for the design of high-end, high-performance XLR or RCA cables.
Reference : 13887
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 25-04-2025.
Neotech NEI-2001
Neotech NEI-2001 Câble de Modulation Argent UP-OCC Blindé PTFE Ø11mm
The Neotech NEI-2001 cable consists of 3 pure silver conductors with shielding. It is perfectly suited for the design of high-end, high-performance XLR or RCA cables. Each of these conductors is composed of 3 silver wires and 4 PTFE wires, all covered with another PTFE sheath for a diameter of 2.65mm. Each silver strand has a different diameter and cross-section: 0.4mm 26AWG, 0.51mm 24AWG and 0.65mm 22AWG. The 3 conductors are placed in a PP filling. Around this filling, a shield composed of an Aluminium-Mylar sheet considerably reduces EMI/RFI interference and can be welded simply with a 0.57mm diameter wire with a 23AWG cross-section. Finally, a thick 2mm PVC sheath and a braided sheath finish this cable with a total outside diameter of 11mm.
Product typeInterconnect cable
Conductors materialPure silver
Number of conductors3
Conductor composition4x PTFE strands
1x Silver strand 0.129mm²
1x Silver strand 0.205mm²
1x Silver strand 0.258mm²
Conductors insulation materialPTFE
Shielding materialAluminium-Mylar Foil
Filling materialPP
External sheathsPVC sheath + Braided sheath
Total external diameter11mm
LengthSold per meter
Diameter (mm)11.0
Length (m)Sold by length
Insulation materialPTFE
ShieldingYes
Section (mm²)0.258
Section (mm²)0.129
Section (mm²)0.205
Conductors material (Cable)Silver
Ground / ShieldingYes
6 reviews
Neotech silver
Bought this out of curiosity to check how good it can be against established brands. I have build this Nei-2001 with Aeco silver plated XLR"s . I'm amazed how god it sounds. It's still new so it only get's better with burn in. It seems to be very detailed and articulate, air around instruments is very nice. Sound seems to be denser more defined and most importantly very! engaging.. I like it a lot ,it's way better than my previous reference XlLR (which was for years nordost quatro fil )
This review has been posted for NEOTECH NEI-2001 Interconnect Cable Pure Silver Shielded PTFE Ø11mm
Bon rapport qualité prix
J'ai constitué un jeu de câbles XLR droite gauche avec quatre fiches ETI KRYO XLR (deux males et deux femelles en rouge et noir) pour relier en symétrique un ampli audio GD A1 avec un DAC MATRIX X-Sabre Pro MQA. J'écoute principalement des fichiers Qobuz suréchantillonnés en DSD 64.
Le montage n'est pas très compliqué : trouver le schéma de câblage sur internet ne pose pas de problème et la soudure du câble sur les fiches non plus à condition de savoir souder (j'ai fait appel à un pro). J'au utilisé de la soudure MUNDORF SUPREME Étain à Souder Soudure Argent 10% qui me paraît adaptée.
Comme j'ai aussi des fiches bananes ETI KRYO pour le raccordement des enceintes, l'ensemble des prises à l'arrière de l'Audio GD A1 est esthétiquement homogène.
Conclusion : avec ce câble et les fiches ETI KRYO on obtient un très bon et beau câble pour un prix qui est dans la moyenne du marché à ce niveau de qualité.
A noter la qualité de service d'Audiophonics qui est toujours très réactif et expédie immédiatement les produits quand ils sont mentionnés comme étant en stock.
Parfait
Très bon câble monté sur des VIBORG XF-202R mâles et femelles pour du xlr. Le son est très propre, détaillé, transparent et avec de bons timbres. Le diamètre des fiches et du câble s'emboîte parfaitement sans avoir besoin de rajouter d'embout. Attention à la soudure, du flux de soudure est nécessaire. Je recommande.
Excelente
Um cabo excelente, equilibrado, tem tudo o que se exige de um cabo hi end, silencio, capaz de reproduzir sem excessos nem limites o que o seu sistema tiver para dar.
Neotech Silver
Was bought to build some phono cables from my Systemdek turntable and also make some interconnects between phono stage and amp, truly outstanding results, recommended.
The Neotech NEI-2001 cable consists of 3 pure silver conductors with shielding. It is perfectly suited for the design of high-end, high-performance...
