NEOTECH NEI-3001G Balanced Interconnect Cable
Neotech NEI-3001G is a balanced interconnect cable incorporating 4 UP-OCC copper conductors 99.99998% pure. It benefits from a top-of-the-range design with two single-core and two multi-strand conductors. In addition, graphene is used to greatly improve the conductivity of this cable's UP-OCC copper conductors.
Reference : 19215
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 17-11-2026.
Câble vendu au mètre
NEOTECH NEI-3001G Balanced Interconnect Cable G-UPOCC Graphene Ø10.5mm
NEOTECH NEI-3001G cable photo
Neotech NEI-3001G is a balanced interconnect cable incorporating 4 G-UPOCC copper conductors 99.99998% pure. It benefits from a top-of-the-range design with two single-core and two multi-strand conductors. In addition, graphene is used to greatly improve the conductivity of this cable's G-UPOCC copper conductors.
Dielectric insulators are a clever mix of alternating polyethylene (PE) air tubes within a symmetrical design. This design minimizes capacitance effects. The PE conductors and tubes are held in place by PTFE insulating tape, preventing the transmission of electrical and static discharges created by the double Mylar/aluminium shielding and OCC copper foil. The whole assembly is encased in a sheet of paper with cotton fibers for mechanical strength, then covered with a robust, flexible PVC sheath.
Product typeBalanced interconnect cable
Conductor materialUP-OCC copper with graphene (G-UPOCC)
Conductors2x single-core conductors
2x multi-strand conductors
Insulation5 polyethylene tubes
PTFE tape
PVC outer sheath
ShieldingAL MYLAR aluminum foil
OCC braided copper foil
Textile paper
External diameterØ10.5mm
ColorBlue
PackageSold by the meter
Diameter (mm)10.5
Number of conductors4
Insulation materialPE
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
4 reviews
Très bon câble.
Agréablement surpris par ce câble à un très bon RqP. Câble relativement souple et facile à travailler, on ressent le savoir faire et la qualité NEOTECH.
Utilisé avec des RCA DG-201, ils viennent en remplacement de câbles symétriques pur argent (retour au cuivre).
Un bel équilibre sur tout le spectre, mais par dessus tout, les voix sont plus claires sans être mise en avant. 4 conducteurs mixtes (multi brins et mono), j'ai testé les variantes et le couplage mono-multi ensemble me convient mieux. Je conseille vivement.
This review has been posted for NEOTECH NEI-3001G Balanced Interconnect Cable G-UPOCC Copper Graphene Ø10.5mm
Neotech Nei-3001G
sehr gutes Kabel.........mehr Transparenz und Präzision im Sound
Updating interconnects
I have now switched to Neotech cables through my system. Have used the NEOTECH NVVD-2001 pure silver 75 ohm for some time in cd transport and streamer via digital transformer to AUDIO NOTE DAC. Excellent results. The NEI 3001G balanced inter connecter (NEOTECH DG 201 RCA PLUGS ), are connected to the PRIMA LUNA pre/power amp. Better details, very clear, improved throughout the change and also in depth of the music, which was quit a surprise. And yes, I have also changed the speaker cable from Neotech at Audiophonics!
Transparency!!!
I have replaced my old RCA interconnects with this cable, terminated with ETI Brio (Rhodium plated) connectors. I have used the blue pair as signal conductor, and the solid copper red wire for the grounding connection. I have used a tiny silver cable soldered to the shielding of the cable to SEPARATELY ground the shielding. (I have a grounding terminal on my Puritan power conditioner so it was easy to drain the sheild there.)
It is very very good quality as you might expect. It is also easy to work with, it was relatively painless to build my own RCA cable.
As for the sound, one word comes to mind: TRANSPARENCY. It lowered the noise floor and have brought more separation to the "layers" of sounds, more detail too. At first it sounds like it has a bit less bass but in reality it tightened the bass and have provided more realism. As you can tell I am super happy with this cable and I will buying more to building XLR cables in the future.
I highly, highly recommend the NEI-3001G if you need a transparent, high-end sound.
 (4)
Neotech NEI-3001G is a balanced interconnect cable incorporating 4 UP-OCC copper conductors 99.99998% pure. It benefits from a top-of-the-range...
