NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables.
The Neotech NEMOI 3220 modulation cable, combining PTFE insulation and OCC pure copper conductors with a rectangular section, has a special architecture allowing a strong reduction in the effect of inductance and capacitance.
If you are looking for a high resolution cable, the Neotech NEMOI 3220 can meet this expectation.
4.9 / 5
Reference : 11422
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 24-04-2025.
1MII B08+ Class D Amplifier Bluetooth 5.0 Receiver AAC SBCI QCC3034 2x50W / 4 Ohm
NEOTECH NEMOI-3220
BALANCED INTERCONNECT BRAIDED CABLE OCC PTFE Ø10MM
The result is surprising, combining listening qualities that are often contradictory, such as a seat in the bass and a readable, natural sound stage with High Definition in the midrange without auditory fatigue.
The shield can also be used as a conductor.
- Cable structure OCC Neotech NEMOI 3220 -
NEMOI-3320 Structure OCC Neotech
Technical characteristics :
  • 2 OCC copper conductors with rectangular section + 1 copper shielding sheath
  • 3-layer insulation : PTFE and Polyethylene in second layer, PVC outer sheath
  • Cable outer diameter: 10mm
  • Sold by meter
Diameter (mm)10.0
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
15 reviews
Ce câble est bien dynamique, beau grave et bas médium.
Il met juste légèrement les aigus en arrière .
Il me fait pensé au câble secteur Furutech T 31 ( vert ) pour ses timbres .
This review has been posted for NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
Excellent câble symétrique
J'avais déjà réalisé des câbles RCA avec ce 3220 mais je n'avais pas vraiment d'autres câbles pour faire un comparatif.
J'ai réalisé deux câbles symétriques d'environ 80cm avec des connecteurs Viborg XM et XF 202G. Je l'ai comparé à des câbles que j'ai fait avec du câble Canare L-4E6S et les mêmes connecteurs (je les aime bien).
Ces câbles sont entre un DMP-A6 et un Hegel H190.
Avec le 3220, le son est plus plein, plus vivant. Les graves sont toujours là, plus percutant encore, le medium est mieux placé et les aigus se sont étoffés, sans être agressifs.
Les points chaud et froid (2 et 3) sont connectés des deux cotés. Le blindage (1) n'est connecté que du coté source, sur les deux câbles.
J'aime beaucoup ce câble.
 (5)
up occ copper cables
I ordered this cable after having very good results with the NEI 3004 interlink cable. I used for this cable the AECO pure copper RCA plugs.
I am curious what the NEMOI 3220 with AECO ARP-4045 RCA plugs will do in my setup. I will come back as soon as the interlink is ready and is listen at.
I have not been listening to it
Vraiment EXCELLENTS
J'ai eu une expérience malheureuse avec ces câbles branchés entre un petit dac Audio GD et mon ampli (AF 3S) et depuis ils dormaient au fond d'un tiroir. Mais je viens d'acquérir un lecteur CD (MT CD One) et par curiosité je les ai branchés entre le MT et l' AF 3S et là grosse surprise c'est vraiment excellent , une très grande transparence tout en étant chaleureux : parfait ! Et je comprends aujourd'hui qu'il faisait bien ressortir les défauts du dac Audio GD qui d'ailleurs est revendu depuis longtemps . Pour infos les fiches sont des RAMM AUDIO 30891
perfect
quiet background calm presentation and previously unnoticed details
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The Neotech  NEMOI 3220...
