NEOTECH NEMOI-5220 Balanced interconnect braided Cable OFC PTFE Ø8.5mm
4.5 / 5
Reference : 11421
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 16-07-2026.
The NEMOI series from manufacturer Neotech is the result of extensive research in the field of audio cable.
The modulation cable Neotech NEMOI 5220mixing insulation PTFEand pure rectangular section OFC copper conductors has a particular architecture allowing a strong reduction in the inductance and capacitance effect.
If you are looking for a high-resolution cable, Neotech NEMOI 5220may correspond to this expectation.
The result is surprising mixing with the listening qualities often contradictory like seated in the grave and readable, natural sound scene with a High Definition in the medium without auditory fatigue.
The shielding can also be used as a conductor.
- OFC cable structure Neotech NEMOI 5220 -
Neotech occ cable
Features:/ Strong>
  • 2 Conductors OFC copper with rectangular section + 1 sheath copper sheath
  • 3-layer insulation: PTFE and Polyethylene in second layer, PVC outer jacket
  • External Wire Diameter: 8.5mm
  • Sold by the meter
Diameter (mm)8.5
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
4 reviews
The beauty and the tuff one
This is are very stiff cable but making a interconnect with it is certainly worth it.
The conductors are double insulated so after the first layer there is a ptfe layer so be aware of that.
The outer sleeve is also made of two layers of witch one can be peeled of if you are careful not to cut too deep this makes smaller cable entrance diameter RCA plugs possible to fit.
Compared to a expensive silver cable it loses some fine nuances but gains in solidity and warmth it is not a"warm" cable but very neutral and resolving.
This review has been posted for NEOTECH NEMOI-5220 Balanced interconnect braided Cable OFC PTFE Ø8.5mm
Joli Design mais qualité sonnore a revoir
Beau câble, bien construit et semble de très bonne qualité.
Niveau qualité sonore, il fait mieux qu'un câble RCA bon marché mais a une scène sonore plus étroite que beaucoup de câbles.
vraiment bien
Voilà une solution peu chère, si l'on soigne les RCA, pour obtenir un résultat équilibré. Mais son grand frère 3220 va plus loin et offre une écoute encore plus agréable avec un bas medium plus musclé.
Mais c'est plus cher, donc le choix de l'un ou l'autre se justifie.
Extra
Reçu aujourd'hui et monté dans la foulée avec rca elecaudio résultat top le son est trés détaillé et tous les registres à leurs places je les trouvent trés neutres ce qui pour moi est ce que l'on demande à un cable bravo neo
