Pur Copper OFC Silver Plated shielded Cable High Purity PTFE Ø3.8mm
Reference : 11458
6,90 €tax incl.
5,75 € tax excl.
This high quality 99.9998% silver-plated OFC 99.9998% copper shielded multi-stranded twisted modulation cable is suitable for any DIY assembly. It is made entirely of PTFE insulation, conductors and outer jacket and is suitable for use as a high quality balanced and unbalanced modulation cable.
Thanks to its noble materials, it will keep good electromechanical characteristics over time. To be perfectly adapted on Amphenol XLRs with a large internal diameter, you can use Grommet AC adapters.
Suggested RCA connectors:
Specifications:
  • Two conductors (one black, one white) 99.9998% OFC Copper Silver Plated
  • Silver plated strand shielding screen
  • Insulating PTFE sheath on all conductors and outer jacket
  • PTFE resistance: -65°C to 200°C
  • Internal cross-section of each Conductor: 0.8mm².
  • Outer Diameter of Cable: 3.8mm
  • 19 strands per conductor, 0.2mm per strand
  • Inner diameter of each conductor 1.48mm
  • Color of the sleeve : Red or white
Diameter (mm)3.8
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)0.80
Ground / ShieldingYes
2 reviews
Je n'ai qu'un mot : bluffant...Tout y est, transparence, tenue du grave. nettement supérieur à mon câble NBS Dragon que j'avais payé 2500 F il y a quelques années, soit pas loin de 400€. Du coup je vais en commander pour ma platine vynile.
This review has been posted for Pur Copper OFC Silver Plated shielded Cable High Purity PTFE Ø3.8mm
superbe
un câble de modulation est fait pour faire transité un signal électrique ,d'un point a vers un point b et celui la le fait très bien,sans ajouté ou retiré quelque chose.le son son est propre, limpide ,avec beaucoup de clarté et de détails.il est cependant dommage que d'autre câbles du même type ne soit plus aux catalogue audiophonics
