RAMM AUDIO E72 Interconnect Cable OCC Copper Ø8mm
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of three 0.5mm OCC copper strands, combined with four PP tubes filled with air as dielectric and an aluminum-mylar shield. The E72 also has a drain wire, composed of three 0.65mm OFC copper strands.
Reference : 15903
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 22-04-2025.
Câble vendu au mètre
Ramm Audio E72
Interconnect cable OCC copper Ø8mm
Ramm Audio E72 câble de modulation cuivre OCC Ø8mm
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of three 0.5mm OCC copper strands, combined with four PP tubes filled with air as dielectric and an aluminum-mylar shield. The E72 also has a drain wire, composed of three 0.65mm OFC copper strands. The filling uses cotton. Then comes a general aluminum-mylar shielding, followed by a flexible and robust PVC sheath.
Ramm Audio Elite 72 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeInterconnect cable
Conductor materialOCC Copper
Conductors diameterØ3mm
Conductors section2x1.7mm²
DielectricPP Tubes
ShieldingAluminium-Mylar foil
Drain wireOFC Copper
External sheathPVC
External diameterØ8mm
Diameter (mm)8.0
Number of conductors2
Insulation materialPolypropylene (PP)
ShieldingNo
Section (mm²)N/A
Ground / ShieldingYes
5 reviews
Sonic master
These cables are true gems, I have many interlinks , from mogami with low mass elecaudio connectors and chord C-line, to XLO reference , signature, wireworld gold eclipse 8 is my daily driver and beats the pants off of all else that came through… however a cable I constructed with this
This review has been posted for RAMM AUDIO E72 Interconnect Cable OCC Copper Ø8mm
Excellent cable interconnect RCA
Associé à des connecteurs NEUTRIK NF2CB2 et soudé à l'étain avec 4% d'argent, enterre mon câble RCA à 350 EUR soit disant audiophile. Un exemple de neutralité sur toutes les fréquences. Attention un peu rigide et très long à dénuder pour retrouver proprement les 3 petits conducteurs à chaque fois, mais l'effort est mérité. J'ai utilisé le fil rouge pour l'âme centrale, le blanc pour la masse et le blindage connecté coté source. De plus le câble est fléché donc je reconnais facilement le coté ou le blindage est branché sur la masse. Du coup je vais remplacer 1000 EUR de RCA par ces câbles DIY!
TRES BON
Très bon câble monté avec des prises RCA ELECAUDIO RC90. je trouve qu'il restitue très bien l'acoustique des endroits ou les prises de son sont faites. Je le trouve plus qualitatif que mes câbles précédents, très belle voie, moins d'agressivité dans les aigus (ensemble full Atoll + triangle). Bref un super rapport qualité, je le recommande chaudement.
Très musical !
Montage fait avec des connecteurs Ramm vissants. On passe les problemes dus a la rigidité des gaines et la vis minuscule mal adaptée pour serrer 3 minuscules brins de 0,5 mm. Le résultat est tout bonnement stupefiant, précision, ciselé, avec des timbres magnifiques. Il devient mon meilleur câble actuel après en avoir testé beaucoup dans cette gamme de prix et même 3 a 4 fois plus cher.
RQP imbattable
Ramm audio reste fidèle à ses habitudes : rigueur et qualité.
Facile à mettre en œuvre et associé aux fabuleuses nouvelles prises Rca de chez Xsangsam sans soudure, au prix dérisoire, le résultat final est bluffant.
J’ai monté les deux fils sur le point chaud et la tresse à la masse des deux côtés.
A l’écoute, il se dégage un mélange de dynamisme et de finesse avec des aiguës exceptionnels.
La magie opère au bout de 20/30 heures de chauffe avec des timbres justes et aérés.
A écouter d’urgence, vous n’en croirez pas vos oreilles.
En conclusion, ces deux nouveaux produits , Cable Ramm et prises Rca proposés par audiophonics remontent encore le niveau du RQP.
Alors un grand merci aux acheteurs de cette belle entreprise.
Bravo audiophonics
Patrick
 (3)
The Ramm Audio E72 modulation cable offers excellent design quality for perfect signal transmission. It features two conductors, each consisting of...
