SOMMERCABLE ISOPOD SO-F22D Balanced Interconnect Cable OFC Copper Ø3.3mm 110 Ohm
The Sommercable SO-F22D is a symmetrical cable with aluminium foil shielding having the particularity of offering an external diameter reduced by 3.3mm for easy integration.
Reference : 12857
0,90 €tax incl.
0,75 € tax excl.
Sommercable SO-F22D
Balanced interconnect cable 2 x 0.22m² PVC ⌀ 3.30mm Gris
Sommercable SO-F22D Câble de modulation symétrique 2 x 0.22m² PVC ⌀ 3.30mm Gris
The Sommercable SO-F22D is a symmetrical cable with aluminium foil shielding having the particularity of offering an external diameter reduced by 3.3mm for easy integration. This will be ideal for internal wiring of your components, especially since its construction ensures a certain flexibility. In addition, the copper strands used are pre-twisted and will allow simple stripping. For ease of installation, the cable has an additional drainage conductor, also pre-twisted. Similarly, it is protected by an ALP/PT sheet that automatically adheres to the sheath when stripped.
Cable typeBalanced 110Ω AES/EBU
Conductors materialHigh purity OFC Copper
Composition(2LI2Y0.22mm²)(ST)Y
Sheath materialPVC
Diameter3.3mm
ShieldingAL / PT film + wires, tinned
InsulationPP 1.30⌀
Standard connector insulationPE 1.12mm
AES/EBU conductor insulationPE 1.3mm
Internal conductors2 x 0.22mm²
Copper strands7 x 0.20mm
Operating temperatures-30°C / 70°C
Impedance110Ω
ColorGray
Diameter (mm)3.3
Length (m)Sold by length
Number of conductors2
Insulation materialPE
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)0.205
Ground / ShieldingYes
The Sommercable SO-F22D is a symmetrical cable with aluminium foil shielding having the particularity of offering an external diameter reduced by...
