SOMMERCABLE SC-Cicada SO-D14 Interconnect Cable OFC Copper Microphone 2x0.14mm²
This Sommercable SC-Cicada SO-D14 is a microphone modulation cable with a cross-section of 2x 0.14mm². Its conductors are made of pure OFC copper for optimum signal transmission. This modulation cable is particularly appreciated for its high flexibility and durability, thanks to a number of protective features.
Reference : 18753
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 16-04-2025.
Câble vendu au mètre
Photo of SOMMERCABLE SC-Cicada SO-D14 cable
This Sommercable SC-Cicada SO-D14 is a balanced microphone modulation cable with a cross-section of 2x 0.14mm². Its conductors are made of pure OFC copper for optimum signal transmission. This modulation cable is particularly appreciated for its high flexibility and durability, thanks to a number of protective features: tight spiral braiding and pre-twisted, tin-plated drain wires. These features make it highly resistant to bending and tearing. Moreover, with its Ø2.6mm diameter, it is particularly suited to areas where space is limited. It is also shielded, and an outer PUR sheath covers the whole for resistance against nicks and high temperatures.
Sommercable SC-Cicada SO-D14 highlights:
  • Litz wire structure
  • Easy handling thanks to additional drain wire (0.22 mm²)
  • Excellent shielding thanks to tight helical mesh (95% coverage)
  • Durable and cut-resistant thanks to sturdy PUR (polyurethane) sheathing
Technical characteristisc
Product typeInterconnect cable
ConducorsOFC Copper
Cross-section2x 0.14mm²
Shielding
Balanced
Outer sheathPUR (Polyurethane)
PackageSold by meter
Diameter (mm)2.6
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)0.14
Ground / ShieldingYes
SOMMERCABLE SC-CICADA SO-D14 Interconnect Cable OFC Copper Microphone 2x0.14mm²
This Sommercable SC-Cicada SO-D14 is a microphone modulation cable with a cross-section of 2x 0.14mm². Its conductors are made of pure OFC...
