SOMMERCABLE SC-SCUBA 14 HIGHFLEX Cable Modulation Symmetric Ø3.8mm
Reference : 3342
1,30 €tax incl.
1,08 € tax excl.
Shipping date: 23-04-2025.
SOMMER CABLE - SC-SCUBA 14 HIGHFLEX
It will go everywhere ...
where you plan to use it, the new SC-SCUBA 14 HIGHFLEX: It is very thin, space-saving and very flexible. These features make it ideal for patch use on LEMO elements or for connecting to small diameter connectors (Cinch, mini jack etc.), as well as for rack cabling. The dimensions and composition of the conductors are in accordance with current broadcasting standards, and a copper braid with a 90% overlap provides protection against interference.
ADVANTAGES:
  • Very fine, tensile strength, flexible
  • available in five different colors
  • Efficient shielding by dense copper braid
  • Very good price
  • Outside diameter 3.8mm
USE:
  • Patch cable (LEMO), cable for gooseneck microphones
  • Recording systems home
  • Wiring racks or desks
Specifications:
Constitution(2LI2Y0,14mm2) CY
Envelope, diameter PVC 3.8 mm
AWG26
Conductor inside 2 x 0.14 mm2
Copper strands per core 18 x 0.10 mm
Insulation of the conductorPE1.15 mm
Protectionbraid of tinned copper wire 0.10 mm
Optical cover92%
Operating temperature min. -20 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.09 kWh
Weight parm25 g
Packaging unit, packing unit roller 100/500 m
ColorGrey
Electrical Specifications:
Capacity metric cond./cond. 68 pF
Metric Capacity Screen / Display 130 pF
Odometer Resistance, Conductor 53 Ohm
Resistance, shielding 25 Ohm
Resistance kilometric, insulation > 1 GOhm
Impedanceabout 100 Ohm
Reference Number:
Reference number200-0316
Recommended retail priceon demand
Diameter (mm)3.8
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingYes
Section (mm²)0.14
Ground / ShieldingYes
