SOMMERCABLE STAGE 22 HIGHFLEX Modulation cable 2x0,22mm² Ø6.4mm
Reference : 1477
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 25-04-2025.
symmetrical
SOMMER CABLE - Stage 22 highflex
A thick skin ...
protects interior components against pulling, pressing and intertwining. It is for this purpose that we have wrapped the STAGE 22 in a sheaththick 6.4 mm in diameter. However, its construction and its electrical characteristics are also remarkable: The STAGE 22 exhibits a low capacity value and a high resistance to alternate bending due to the fine and tightly twisted strands composing the conductor cores.
Theshielding is ensured by white copper winding is guaranteed a 90% optical coverage (instead of the usual 85%). From there, the STAGE 22 is the ideal cable for the VCR, stage, distributor and installer technician.
Despiteits advantageous price, the STAGE 22 does not require you to compromise.
ADVANTAGES:
  • High quality of retransmission due to the souls composed of fine strands
  • Very robust thanks to its soft PVC sheath
  • Efficient shielding by dense copper shielding
  • High flexibility, easily rollable
  • Very interesting price
USE:
  • Scenic technique
  • VCR
Specifications:
Constitution(2LI2Y0,22mm2) DY
Envelope, diameter PVC 6,4 mm
AWG24
Conductor inside 2 x 0.22 mm2
Copper strands per core 32 x 0.10 mm
Insulation of the conductorPE 1,40 mm
Protectionhelical coil winding of 0.10 mm
Optical cover99%
Operating temperature min. -20 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.22 kWh
Weight per m55 g
Colorblack
Electrical Specifications:
Capacity metric cond./cond. 68 pF
Metric Capacity Screen / Display 130 pF
Odometer Resistance, Conductor53 Ohm
Resistance, shielding25 Ohm
Resistance, insulation> 1 GOhm
Impedanceabout 100 Ohm
Diameter (mm)6.4
Length (m)Sold by length
Number of conductors2
Insulation materialOther
ShieldingYes
Section (mm²)0.22
Ground / ShieldingYes
juste génial
bien souple facile a étamé parfait utilisé pour faire un câble de liaison de 10m bon par contre la gaine tresser est une véritable galère a mettre y a surement une méthode ou un outil mais bon au bout de 3heure a fabriquer mon câble le son sort clairement avec des basse plus présente un medium aiguë précis rien a dire c'est du tout bon
This review has been posted for SOMMERCABLE STAGE 22 HIGHFLEX Modulation cable 2x0,22mm² Ø6.4mm
