SOMMERCABLE TRANSFER AMCK10 Multicore Cable Ø10.8mm
Reference : 10091
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 16-04-2025.
Symmetrical, insulated and shielded pairs by helical coil Cu + overall shielding by Cu braid
SOMMERCABLE - SC-TRANSFER HIGHFLEX AMCK10
Five years of reprieve ...
this is what all acoustic, radio and TV technicians were waiting for!
In cooperation withcoustics and several broadcasting establishments, our technique has developed a multipaire cable suitable for use in outdoor areas and under extreme conditions.
Available immediately from our warehouse, the new SC-TRANSFER HIGHFLEX is equipped with a PUR envelope of the "MASTER BLEND" type.
Ofmade of the robustness and high resistance to the notching of this envelope, we guarantee a five year warranty on the cable per meter!
CettThe envelope keeps its strength even in winter: stability guaranteed up to a temperature of -40 ° C. It is also resistant to heat and scoring.
ThePUR outer sheath and special TPE-Hytrel® conductor sheaths are suitable for extreme conditions and demonstrate high flexural strength, ground traction and tensile strength.
Thiscould naturally also be used as a high quality conductor for various installations and stage equipment.
Multi-pair cable and power cable: see DMX SC-MONOLITH POWER DMX multiconductor.
10 pairs version, halogen-free, anti-flammable.
ADVANTAGES:
  • Super-fine diameter, high resistance
  • Additional insulation in pairs with numbered PVC sleeves
  • Excellent protection against interference, by tubular overall braid of tinned copper and by ehelical copper winding on the pairs of conductors
  • Very good audio retransmission due to the narrow torsade of the souls
USE:
  • Roll-up cable for broadcast studios and vehicles
  • Indoor and outdoor fixed installations
  • Extremely robust stage and stage housing
  • Very good protection against interference, ideal for studios
Specifications:
Constitution[Xx (2LI2Y0,14mm2) DY] CY PUR
Envelope, diameterPUR Master Blend 10.8 mm
AWG26
Conductor inside10 x 2 x 0.14 mm2
Copper strands per core18 x 0.10 mm
Insulation of the conductorPE 0,85 mm
Protectioncopper winding per pair, overall screen by tinned copper braid
Optical cover90%
Operating temperaturemin. -40 ° C
Operating temperaturemax. 70 ° C
Operating temperaturein accordance with ISO458
Fire resistance per m0.45 kWh
Weight per m174 g
Color of envelopeblack
Packaging unit, packing unitper meter
TypeFRNC
Electrical Specifications:
Metric capacitythat cond./cond.85 pF
Metric Capacity Screen / Display140 pF
Odometer Resistance, Conductor<138 Ohm
Resistance, shielding<125 Ohm
Resistance, insulation> 1 GOhm
Characteristic Impedance75 Ohm
Diameter (mm)10.8
Length (m)Sold by length
Number of conductors20
Insulation materialPET
ShieldingYes
Section (mm²)0.14
Ground / ShieldingYes
