SOPERCABLE ISOPOD SO-F22 Symmetrical Modulation Cable Ø3.3mm
4.7 / 5
Reference : 3343
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 23-04-2025.
https://www.audiophonics.fr/images2/783/Isopod_22_schwarz.gifsymmetrical
SOMMER CABLE - SC-ISOPOD SO-F22
The cable and its memory ...
help to make the storage. The interior of the distribution cabinets and racks often resembles the knitting drawers of our grandmothers. Let's put them in order! The SC-ISOPOD SO-F type is a low-diameter (3.3 mm or 4.2 mm) dual-core dual-wire cable equipped with a sheet screen. It is used on the front line for interior wiring of audio and hi-fi components. It has a "memory effect" is can be laid "in the corners" without difficulties. The pre-twisted core of the conductors is made of copper and allows itself to be stripped very easily. To facilitate connections, the cable is equipped with an additional drainage conductor, also pre-twisted and tin-plated. The cable is protected by an AL / PT sheet that automatically adheres to the sheath when uncovered.
The type SC-ISOPOD SO-F50 has a large section (2 x 0.50 mm²) and is preferably used with crimp contacts.
The type SC-ISOPOD SO-F22D with a characteristic impedance of 110 Ohm (Order No. 500-0406, see below).
ADVANTAGES:
  • Quick and easy handling
  • High durability due to the robust outer sheath, made of specially designed material
  • Easy installation thanks to its "memory effect"
USE:
  • Interior wiring for racks and audio / hi-fi components
Specifications:
Constitution(2LI2Y0,22mm2) (ST) Y
Envelope, diameterPVC 3.3 mm
AWG24
Conductor inside2x0.22 mm2
Copper strands per core7x0.20 mm
Standard driver insulationPE 1,12 mm
AES / EBU Conductor InsulationPP 1.3 mm
Protectionsheet AL / PT + mass drain, tinned
Optical cover100%
Operating temperaturemin. -30 ° C
Operating temperaturemax. 70 ° C
Fire resistance per m0.05 kWh
Weight per m16 g
Packaging unit, packing unitroller 200 m
Colorblack
Specificae:
Capacity metric cond./cond.74 pF
Metric Capacity Screen / Display143 pF
Odometer Resistance, Conductor<80 Ohm
Resistance, shielding75 Ohm
Resistance, insulation> 1 GOhm
Reference Number:
Reference number200-0401
Recommended retail priceon demand
Diameter (mm)3.3
Length (m)Sold by length
Number of conductors2
Insulation materialPTFE
ShieldingYes
Section (mm²)0.22
Ground / ShieldingYes
3 reviews
Bon câble ...
Bon câble, mais un peu fin du niveau du diamètre ext, pour une bonne fixation dans la plupart des connecteurs
This review has been posted for SOPERCABLE ISOPOD SO-F22 Symmetrical Modulation Cable Ø3.3mm
sans prétention …
Sans prétention ce câble fait le job.
Son défini, clair et précis. Le message est respecté de bas en haut.
Facile à mettre en œuvre, on peut le contraindre un peu sans souci (mémoire de forme) pour du câblage fixe ou interne.
Très hautement recommandable pour du petit budget.
Bon petit câble
Bon petit câble, fait le job, attention en dénudant d'y aller doucement si vous ne voulez pas couper le film de blindage, sinon ça marche aussi très bien en le coupant (au début du coup de pensais que le câble n'étais pas blindé). A utiliser sans hésitation pour tout câblage standard en interne ou en fixe.
