AECO ABP-1111S Banana Plugs Silver Plated Copper Ø6mm (Set x4)
These high-quality AECO ABP-1111S banana plugs are sold in packs of 4 and feature an ingenious design incorporating top-of-the-range materials. The contacts of these banana plugs are made of 99% pure copper with 120µ silver plating for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18319
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-04-2025.
AECO ABP-1111S
AECO ABP-1111S Banana Plugs Copper Silver Plated Ø6mm (Set x4)
These high-quality AECO ABP-1111S banana plugs are sold in packs of 4 and feature an ingenious design incorporating top-of-the-range materials. The contacts of these banana plugs are made of 99% pure copper with 120µ silver plating for enhanced conductivity and resistance to corrosion and oxidation. Their body is solid. The POM (polyoxymethylene) head lock and internal plastic sheath act as insulation. They can be assembled either by screwing or welding. The removable structure of these banana plugs facilitates assembly by soldering. They accept conductors with a diameter of 5mm or less for solder mounting, or conductors with a diameter of 3.5mm or less for screw mounting.
Product typeBanana plugs
COntact materialTellurium copper
Contacts platingSilver
Contacts resistance< 0.3mΩ
Body materialBrass alloy
IsolationPOM
Mounting typeTo screw or to weld
Max. cable diameterWithout reducer: Ø6.5mm
With reducer: Ø4.5mm
Max. conductor diameterTo screw: Ø3.5mm
To weld: Ø5mm
Total dimensionsØ9 x 43mm
ColorSilver
QuantitySet x4
Max cable diameter (mm)6.0
Mounting typeTo weld
ConnecticMale
ConnectorBanana
These high-quality AECO ABP-1111S banana plugs are sold in packs of 4 and feature an ingenious design incorporating top-of-the-range materials. The...
