ATOHM WT-MB53-G 24K Gold Plated BFA Banana Plug Red
This BFA WT-MB53-G BFA banana plug from Atohm is a banana plug with 24K gold-plated copper alloy contacts for corrosion and oxidation resistance and maximum conductivity.
Reference : 18935
5,50 €tax incl.
4,58 € tax excl.
ATOHM WT-MB53-G Fiche 24K Gold-plated BFA Banana Plug Ø3.2mm Red (Unit)
Photo of Atohm WT-MB53-G BFA banana plug
This BFA WT-MB53-G BFA banana plug from Atohm is a banana plug with 24K gold-plated copper alloy contacts for corrosion and oxidation resistance and maximum conductivity. This BFA banana plug can be mounted using two screws and/or soldering. The Atohm WT-MB53-G is a high-quality banana plug particularly suited to the Atohm Zef Mini cable and the design of modulation cables for speaker/amplifier terminals.
Atohm WT-MB53-G banana plug dimensions
Product typeBanana plug
COntact materialCopper alloy (Lead-free brass)
COntact platingGold 24K
Mounting typeTo screw and/or weld
Max. cable diameterØ3.2mm
Total length55mm
ColorRed
Package1x ATOHM WT-MB53-G BFA banana plug Red
Max cable diameter (mm)3.2
Mounting typeTo weld
ConnecticMale
ConnectorBanana
ATOHM WT-MB53-G 24K Gold Plated BFA Banana Plug Ø3.2mm Red (Unit)
This BFA WT-MB53-G BFA banana plug from Atohm is a banana plug with 24K gold-plated copper alloy contacts for corrosion and oxidation resistance...
