Banana Plugs BFA 24k Gold-Plated Ø8mm (Pair)
These affordable 24k gold-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The gold-plated contacts provide good conductivity and resistance to oxidation and corrosion.
Reference : 18122
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 24-04-2025.
Banana Plugs
These affordable 24k gold-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The gold-plated contacts provide good conductivity and resistance to oxidation and corrosion. The transparent plastic body reveals the wiring connection for a beautiful aesthetic effect. The cable connectors are screw-type, and another screw holds the cable firmly to the connector. These BFA banana plugs accept cable diameters up to Ø8mm.
Product typeBanana plugs
Contact materialPure copper
Contact material24k gold
Max. cable diameterØ8mm
Mounting typeTo screw
Total length43mm
Connector length20mm
Max. body diameter17mm
Identification rings
ColorTransparent and gold
Weight6g/Banana plug
PackageBFA Banana plugs (Pair)
Max cable diameter (mm)8.0
ConnecticMale
ConnectorBanana
These affordable 24k gold-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and...
