Banana Plugs BFA Gold Plated Ø5mm (Pair)
These affordable gold-plated BFA banana plugs provide simple, effective connection to the terminal blocks on your speakers and amplifiers. The gold-plated contacts provide good conductivity and resistance to oxidation and corrosion.
Reference : 18132
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 24-04-2025.
Banana Plugs
Fiches Banane BFA Plaqué Or Ø5mm (La paire)
These affordable gold-plated BFA banana plugs provide simple, effective connection to the terminal blocks on your speakers and amplifiers. The gold-plated contacts provide good conductivity and resistance to oxidation and corrosion. The transparent PVC shell acts as insulation. The cable connectors are screw-type, and a second screw holds the cable firmly to the connector. These BFA banana plugs accept cable diameters up to Ø5mm.
Product typeBanana plugs
Contact materialPure copper
Contact platingGold
Max. cable diameter Ø5mm
Mounting typeTo screw
Total length45mm
Connector length20mm
Max. body diameter14.5mm
ColorTransparent and gold
Weight12g/ Banana plugs
PackageGold-plated BFA banana plug Ø5mm (sold by pair)
Max cable diameter (mm)5.0
ConnecticMale
ConnectorBanana
These affordable gold-plated BFA banana plugs provide simple, effective connection to the terminal blocks on your speakers and...
