Banana Plugs BFA Rhodium-Plated Ø8mm (Pair)
These affordable Rhodium-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts provide good conductivity and resistance to oxidation and corrosion.
Reference : 18130
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 22-04-2025.
Banana Plugs
These affordable rhodium-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and amplifiers. The rhodium-plated contacts provide good conductivity and resistance to oxidation and corrosion. The transparent plastic body reveals the wiring connection for a beautiful aesthetic effect. The cable connectors are screw-type, and another screw holds the cable firmly to the connector. These BFA banana plugs accept cable diameters up to Ø8mm.
Product typeBanana plugs
Contact materialPure copper
Contact materialRhodium
Max. cable diameterØ8mm
Mounting typeTo screw
Total length43mm
Connector length20mm
Max. body diameter17mm
Identification rings
ColorTransparent and silver
Weight6g/Banana plug
PackageBFA Banana plugs (Pair)
Max cable diameter (mm)8.0
ConnecticMale
ConnectorBanana
Fiche banane
Je ne recommande pas ce produit.
La fixation du câble ne me paraît pas très bonne en conductivité.
Ou alors peut être pour du gros câble.
Pas pour moi.
This review has been posted for Banana Plugs BFA Rhodium-Plated Ø8mm (Pair)
These affordable Rhodium-plated BFA banana plugs ensure simple, effective connection to the terminal blocks on your speakers and...
