Banana Plugs Gold Plated Ø6mm (Pair)
These low cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are gold plated to ensure a very good signal conductivity and resistance to oxidation. The cables are held firmly in place by a screw. These plugs accept cables up to 6mm in diameter and conductors up to 4mm.
Product type | Banana plugs |
Contacts material | Copper alloy |
Plating | Gold |
Max cable diameter | Ø6mm |
Max conductor diameter | Ø4mm |
Mouting type | To screw |
Total dimensions | Ø12 x 55mm |
Max cable diameter (mm) |
Mounting type |
Connectic |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
