Banana Plugs Rhodium Plated Ø7mm (Pair)
These banana plugs, although inexpensive, benefit from a beautiful design quality. The lamellae of these plugs allow a very good contact between the connector and the terminal block, as well as a perfect maintenance. The contacts are rhodium-plated, ensuring a good conductivity.
Reference : 15794
5,90 €tax incl.
4,92 € tax excl.
Banana plugs
Rhodium plated Ø7mm
Fiches bananes cuvire plaqué rhodium Ø7mm
Technical characteristics
Product typeBanana plugs
Contacts materialCopper alloy
Contacts platingRhodium
Max cable diameterØ7mm
Max conductor diameterØ5mm
Mounting typeÀ visser
À souder
Max cable diameter (mm)7.0
Mounting typeTo screw
Mounting typeTo weld
ConnecticMale
ConnectorBanana
These banana plugs, although inexpensive, benefit from a beautiful design quality. The lamellae of these plugs allow a very good contact between...
