Excellent produit et pas cher.
Excellent rapport qualité prix.
Petit fin pratique pour les petits amplis avec peu de place connexion du câble parfaite et connexion au bornier également.
Prix la paire déjà 3 achats.
Banana Plugs Silver Plated Ø5mm (Pair)
These low-cost banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers. The contacts are silver plated to ensure excellent signal conductivity. The cables are held firmly in place by two screws. These plugs accept cables up to 5mm in diameter.
Spécifications techniques | |
Type de produit | Fiches bananes |
Matériau des contacts | Alliage de Cuivre |
Plaquage | Argent |
Diamètre câble acceptable max | Ø5mm |
Type de montage | À visser |
Dimensions totales | Ø8.5 x 40mm |
Max cable diameter (mm) | 5.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Silver |
Average votes 3.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-Baptiste G.
Poul T.
Hector S.
