BFA Banana Plugs Rhodium Plated Ø9mm (Pair)
These banana plugs, although inexpensive, benefit from a nice design quality. The BFA design of these plugs allows a very good contact between the connector and the terminal block, as well as a perfect hold. The contacts are rhodium plated, ensuring good conductivity. Mounting is easy thanks to a screw system.
3.7 / 5
Reference : 15795
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 24-04-2025.
Banana Plugs
BFA Rhodium Plated Ø9mm
Fiches bananes BFA plaqué rhodium Ø9mm
Product typeBanana plugs
Contacts materialCopper alloy
Contacts platingRhodium
Max cable diameterØ9mm
Max conductor diameterØ5mm
Mounting typeto screw
Max cable diameter (mm)9.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
3 reviews
très bon serrage et solidité
Pour l'instant à leur niveau qualité / Prix , je n'ai rien trouvé de mieux Très bon serrage et une solidité bien supérieure à tout ce que j'ai pu avoir précédemment. Je les recommande.
This review has been posted for BFA Banana Plugs Rhodium Plated Ø9mm (Pair)
I like them...use them without the sleeve
I like them...use them without the sleeve...the set of two screwws are on same side so it makes an even pressure on the wire
Sad screws
The screws ruin the whole product
A. too short for 2.5mm cables (needes folding them to hold)
B. Pointy tip useless for holding speaker wire
C.magnetic screws
It would be such a good products with longer flathead non magnetic
These banana plugs, although inexpensive, benefit from a nice design quality. The BFA design of these plugs allows a very good contact between the...
