ELECAUDIO TE-B25NP Banana Plug Tellurium Copper (La paire)
3.0 / 5
Reference : 7598
14,90 €tax incl.
12,42 € tax excl.
The first of a product line based on Tellurium Copper, these banana plugs have been designed to offer unmatched conductivity.
By way of comparison, the majority of the connectors on the market are based on brass or bronze having a conductivity index (IACS) of 56% as against 93% for Cu Te.
All in the design of these connectors has been thought (in the background, choice of alloys and in the form) to be able to offer a level of conductivity never reached in this price range.
Since bananas are made of pure copper Tellurium and have a relatively small diameter, avoid heavy cables and favor pure light copper cables as well.
Characteristics:
  • Conductor: Tellurium copper C14500 (IACS conductivity index 93%)
  • Not plated
  • Soldering or crimping
  • Maximum acceptable cable diameter: 2.5 mm (14 AWG - 4.91mm²)
  • Internal Depth: 15.25mm
  • Sold in pairs
https://www.audiophonics.fr/images2/7598/7598_TE-B25NP_1.jpg
https://www.audiophonics.fr/images2/7598/7598_TE-B25NP_2.jpg
https://www.audiophonics.fr/images2/7598/7598_TE-B25NP_3.jpg
https://www.audiophonics.fr/images2/7598/7598_TE-B25NP_6.jpg
https://www.audiophonics.fr/images2/7598/7598_TE-B25NP_4.jpg
Max cable diameter (mm)
  • 2.5
Mounting type
  • To weld
Connectic
  • Male
Connector
  • Banana
Contacts Material (Connector)
  • Tellurium Copper
Contacts Plating (Connector)
  • None
moyen
Produit sympathique de prime abord et ne posant pas de problème de qualité de transmission. Mais au final, fiche mal fichue qui plie et casse sus le poids du câble inséré dans le bornier des enceintes. Problème similaire signalé par un autre client sur une référence similaire.
Bonjour,
L'information a bien été transmise au constructeur, il travaille en effet sur l'amélioration de ces fiches.
Merci pour votre avis.
This review has been posted for ELECAUDIO TE-B25NP Banana Plug Tellurium Copper (La paire)
