ETI BRIO Banana Plugs
These BRIO banana plugs from ETI are top-of-the-range connectors designed with high-quality components. The connector's contacts are made of rhodium-plated tellurium copper for enhanced conductivity, corrosion and oxidation resistance for greater durability.
Reference : 18485
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 23-04-2025.
Banana Plugs Rhodium-plated Tellurium Copper Ø16 x 55mm (Pair)
ETI BRIO Banana Plugs Rhodium-plated Tellurium Copper Ø16 x 55mm (Pair)
These BRIO banana plugs from ETI are top-of-the-range connectors designed with high-quality components. The connector's contacts are made of rhodium-plated tellurium copper for enhanced conductivity, corrosion and oxidation resistance for greater durability. The body is made of brass, providing effective protection against vibration as well as EMI / RFI interference. The use of these banana plugs promises a final result without signal alteration.
Product typeBanana plugs
Contacts materialTellurium copper
Contact platingRhodium
Body materialBrass
Mounting typeTo weld
Max. câble diameter11.6mm
Identification rings
DimensionsØ16 x 55mm
ColorGrey
PackageSold by pair
Max cable diameter (mm)11.6
ConnecticMale
ConnectorBanana
Contacts Material (Connector)Tellurium Copper
These BRIO banana plugs from ETI are top-of-the-range connectors designed with high-quality components. The connector's...
