ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4)
The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated tellurium copper with a very good conductivity level (IACS 95) and a perfect resistance to oxidation. Their optimized shape allows an optimal contact between the connector and the terminal block. The body of the connectors is made of aluminum, both robust and protecting the signal from EMI/RFI interference.
4.0 / 5
Reference : 17285
155,00 €tax incl.
129,17 € tax excl.
Shipping date: 24-04-2025.
ETI LINK Banana
ETI LINK BANANA Fiches Banane Cuivre Tellurium Plaqué Or Ø9mm (Set x4)
The ETI Link Banana accepts cable diameters up to 9mm. Mounting is extremely simple with two Torx screws, no soldering required.
Product typeBanana plugs
Contacts materialTellurium copper
Contacts platingGold
Shell materialAluminum
Mounting2* Torx screws
Max. cable diameterØ9mm
QuantitySold by 4
Max cable diameter (mm)9.0
Mounting typeTo screw
ConnecticMale
ConnectorBanana
Contacts Material (Connector)Tellurium Copper
2 reviews
Not so practical at lest with big wires
Please see my review of the ETI Link Spade, which I find an excellent Product. Here it would be same, but opposite to the Spade version (where you have the same large opening with same, about 1cm long, diameter tube, with 2 screws to hold the wire), the tube, here you enter with the wire and it looses hal of the diameter (the tube) after the first screw. To hold a wire with one screw, just after the opening, makes it for me useless. A shame for that in theory great product.
This review has been posted for ETI LINK BANANA Banana Plugs Gold Plated Tellurium Copper Ø9mm (Set x4)
Musical
Rien a voir avec pangeo et autres qui rajoute des basses et autres la on écoute ce qu'il y a très musical avec de beaux timbres (si votre système en a )
The ETI Link Banana plugs offer a very nice design quality, ensuring an excellent signal transmission. The contacts are made of gold-plated...
