ETI LINK Banana Plug Beryllium Copper Ø9mm (Set x4)
The ETI Link banana plugs provide a high quality connection at a low price. The "sawtooth" contact design allows a perfect connection between the connector and the terminal block. The internal Beryllium Copper parts are housed in a Brass shell, giving the connector excellent conductivity and resistance to mechanical stress.
Reference : 14379
118,00 €tax incl.
98,33 € tax excl.
ETI Link
Banana Plug Beryllium Copper (Set x4)
ETI Link Fiches Banane Cuivre Beryllium (Set x4)
A pair of screws allows you to fix your cable easily and efficiently, while offering the possibility of using a cable with a large cross-section.
The body of the connector is made of Aluminum, rejecting EMI and RF interference that could disturb the signal and therefore the quality of the sound reproduction.
Product typeBanana plug
Conductor materialBeryllium Copper
Body materialAluminium
Connection typeTo screw
Connector body dimensions32.5 x 13.5mm
Connector total dimensions52.3 x 13.5mm
Max conductor diameter4mm
Max cable diameter9.2mm
QuantitySold by set of 4 banana plugs
Max cable diameter (mm)
  • 9.0
Mounting type
  • To screw
Connectic
  • Male
Connector
  • Banana
Contacts Material (Connector)
  • Beryllium Copper
Contacts Plating (Connector)
  • None
The ETI Link banana plugs provide a high quality connection at a low price. The "sawtooth" contact design allows a perfect connection...
