FURUTECH CF-202 NCF (R) Banana Plugs Rhodium Plated Pure Copper NCF Alpha Treatment Ø5.5mm (Pair)
With the CF-202 NCF (R), Furutech unveils high-end banana plugs offering excellent transmission performance with contacts made of rhodium-plated pure copper. This is the brand's first connector to incorporate Nano Crystal² Formula (NCF) technology. This material, the result of many years of R&D, promotes optimum signal conductivity. As a result, these banana plugs enable the design of finished speaker cables of the highest quality.
By buying this product you get 52 loyalty points
Reference : 17857
265,00 €tax incl.
220,83 € tax excl.
Shipping date: 23-04-2025.
Furutech CF-202 NCF (R)
Furutech CF-202 NCF (R) Fiches Banane Plaqué Rhodium NCF Traitement Alpha Ø5.5mm (La paire)
Furutech CF-201 NCF (R) Fourches Plaqué Rhodium NCF Traitement Alpha Ø5.5mm (La paire)
NCF damping ring
Furutech NCF is a special crystalline material with two "active" properties. Firstly, it generates negative ions to eliminate static electricity. Secondly, it converts thermal energy into far-infrared light. This material is combined with nano-sized ceramic particles and carbon powder for additional damping properties. This makes Nano Crystal² Formula the ultimate electrical and mechanical damping material, exclusive to the Furutech brand.
Alpha α Process
Furutech has also developed a two-stage, ultra-low-temperature contact treatment process that significantly improves conductor performance. This Alpha process begins with a deep cryogenization stage for all metal parts. Furutech uses high-end refrigerants (liquid N2 or He) to achieve temperatures between -196°C and -250°C. This process gives the conductors a more stable structure, favoring improved electrical conductivity.
The second stage of this Alpha α process exposes these same parts to a patented demagnetization treatment. This uses controlled attenuation to completely eliminate the magnetization, once again improving conductivity.
Product typeBanana plugs
Contacts materialPure copper
Contacts platingRhodium
Used treatmentsα (Alpha) cryogenic process
NCF material
Max cable diameterØ5.5mm
Mounting typeTo screw or solder
DimensionsØ15.2*60.5mm
Weight33.4g
Max cable diameter (mm)5.5
Mounting typeTo weld
ConnecticMale
ConnectorBanana
Pas de Surprises
Après avoir acheté, monté avec bonheur les fiches RCA, de la même catégorie.(FURUTECH CF-102 NCF), je me suis décidé a changer les fiche bananes de mon câble d'enceinte( Crystal Cable Ultra) , qui avait de simples bananes Furutech cuivre rhodium visée , par ces magnifique Bananes, qui sont d'une fabrication incroyable, qui ont apporté , un gain de finesse, de micros-détails , et un recul du bruit de fond, un petit plus de véracité, mais cela ne fait qu'une semaine , quelles 'tournent' le rodage n'est pas terminé. J'avoue que la remise des soldes d'hiver, mon décidé , à effectuer cet achat qui et quand même conséquent, au vu de la multiplication des prises!!!
This review has been posted for FURUTECH CF-202 NCF (R) Banana Plugs Rhodium Plated Pure Copper NCF Alpha Treatment Ø5.5mm (Pair)
With the CF-202 NCF (R), Furutech unveils high-end banana plugs offering excellent transmission performance with contacts made of rhodium-plated...
