By buying this product you get 39 loyalty points
High performance banana plugs with Rhodium Plated Copper contacts .
Its use for the transit of low voltage signals is also justified by its low electrical resistance.
It is all the more effective in its role as a driver that it benefits here from the anti-magnetism proprietary processFURUTECH Alpha α, lequel takes place 2 steps:
1- Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FURUTECH FP-200R uses a tube connectionto ensure contact with the speaker terminals. When the plug is connected, the cylinder, divided into two parts along a sinusoidal line , ensures a constant and regular pressure over its entire surface.
Internally, the cable is fixed by means of 2 screws to the specially designed shape to maximize the contact surface, and ensure a firm and durable hold. The FP-202R can also be welded for increased reliability .
Characteristics :
Max cable diameter (mm) |
Mounting type |
Connectic |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Average votes 4.9 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Alex C.
jean-luc s.
FRANCIS C.
remy p.
Jean-Christian N.
