Speaker Interconnection Banana Plugs Gold Plated Copper (Set x4)
These interconnecting banana plugs are ideal for quick connection/disconnection of a pair of speakers or to extend a cable easily and quickly. They also provide good conductivity with gold-plated copper contacts.
4.0 / 5
Reference : 17524
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 06-05-2025.
INTERCONNECTION BANANA PLUGS FOR SPEAKERS
Gold plated Copper (Set x4)
Fiches bananes d'interconnexion pour haut-parleurs cuivre plaqué or (set x4)
These interconnecting banana plugs are ideal for quick connection/disconnection of a pair of speakers or to extend a cable easily and quickly. They also provide good conductivity with gold-plated copper contacts. The cables can be easily mounted using a screw system.
Product typeInterconnection banana plugs
Contacts materialCopper
Contacts platingGold
Dimensions46.7*42*10.5mm
Mounting typeTo screw
Max conductor diameterØ3.7mm
Max cable diameter (mm)
  • 3.7
Mounting type
  • To screw
Connectic
  • Male & Female
Connector
  • Banana
Contacts Material (Connector)
  • Copper
Contacts Plating (Connector)
  • Gold
Bien
Bonne idée et bonne qualité mais il ne faudra pas les démonter trop souvent car les vis ne sont pas terribles.
Attention : je pensais que le plastique transparent pouvait être facilement coupé (comme les sucres d’électricien) mais il n’en est rien. Si vous voulez 2 paires séparées il faudra les découper avec une Dremel.
This review has been posted for Speaker Interconnection Banana Plugs Gold Plated Copper (Set x4)
These interconnecting banana plugs are ideal for quick connection/disconnection of a pair of speakers or to extend a cable easily and quickly. They...
